Power Window Help
Okay long story short I have a 84 k10 with power windows. The master power window switch fell apart on me. I attempted to put it back together, it worked long enough for me to get the window up and then it started to smoke from the switch. I must not have put it back together right. So I bought a new switch and now none of the power windows work from the master switch or the passenger switch. I looked but didn't see any fuses for the power windows. Is there a fuse or relay I could have burnt up?
Re: Power Window Help
check the pigtail connector on the back of the switch to make sure that the wires didn't melt when the switch blew up. Also, get a multimeter or test light to see if you still have power to the switch
