Old 09-04-2012, 11:48 PM   #1
Del72Chevy
Del72Chevy's Avatar
Porterbuilt Front Crossmember Install Help
Anyone else have a problem with the four washers on the underneath side not fitting because of the tubes coming out of the bottom being too close to the mounting bolts? I can only fit the nylon nuts. Do I need to cut one side of the washer or can I install without them?
My Build Thread
http://www.67-72chevytrucks.com/vboa...d.php?t=531309
Del72Chevy is offline   Reply With Quote
Old 09-05-2012, 12:20 AM   #2
osaltyone
osaltyone's Avatar
Re: Porterbuilt Front Crossmember Install Help
I think I flattened the side on some of my washers.
osaltyone is offline   Reply With Quote
Old 09-05-2012, 10:36 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
It can be a tight squeeze sometimes. If you have clearance issues, just grind down one side of the washer a little to clear the weld.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-05-2012, 02:32 PM   #4
Del72Chevy
Del72Chevy's Avatar
thanks for the tip nate its all bolted up now
My Build Thread
Old 01-19-2013, 11:31 PM   #5
shacrm
shacrm's Avatar
I can only get one top bolt and one bottom to line up on both sides, is this normal or should all 4 bolts be in both sides?
Shane
shacrm is offline   Reply With Quote
Old 01-21-2013, 01:22 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
Shane
Do you have a pic?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-21-2013, 01:26 AM   #7
shacrm
shacrm's Avatar
I feel stupid I had the bar upside down! Lol
Old 01-21-2013, 06:47 AM   #8
andrewmp6
Don't feel bad we all have had that I'm retarded feeling before when it hits you.
andrewmp6 is offline   Reply With Quote
Old 01-21-2013, 02:29 PM   #9
PBFAB.COM
PBFAB.COM's Avatar
Don't feel bad.... you're not the first and you won't be the last!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
