So we are swapping a th350 and 305 combo out for a 454 an th400. PROBLEM! Th400 had a bolt on yoke. It's from a suburban and the truck is a 81 shorty. What can we do about the driveshaft? It has to be cheap and quick though if possible
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
At the body shop.
Re: Urgent help! Th350 to th400
Slip on goes on a bolt on style.
" That didnt make it any newer " " Dont antique the equipment " |
So what do we need? I know it needs slip in the driveshaft. The th350 is a long shaft trans and the th400 Is shorter.
Look at this and see if it helps http://www.maliburacing.com/auto_tranny_id.htm
You need to get a slip in yoke and have at least 1" in the tailshaft maybe 3/4 but I don't know. I put a 350 in a 4 speed truck using a driveshaft that was behind a 700r. had to change to a 9" tail on the 350 |
Robert Olson Transport
![]() Join Date: Oct 2002
I have always had long bed pickups . The driveshaft with a th400 was always a slip in like on the th350, however the shaft on a 400 was always a two piece. UNfortunately when you are customizing things, its never cheap or easy. IIRC the tailshaft on the th400 is either long or short tail much like the th 350. the short tail is the one with the bolt on driveshaft. the vast majority of the short tail ones were in vans and those van cab truck body trucks they make. Im thinking your only way out is to have a driveshaft custom made.. Also every th400 ive seen in the pickup has a carrier bearing that needs to be installed on the frame..
At the body shop.
You will need a th400 slip yoke and a drive shaft shop to shorten the drive shaft and attach the new yoke.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 09-05-2012 at 09:46 AM. |
At the body shop.
http://www.drivelinesnw.com/
Alright so I can either convert the trans to slip yoke or have a new driveshaft made basicly.
Can't gO two piece cause that will be too weak for a truck like this that will see track time Posted via Mobile Device
#9 | |
At the body shop.
Track time? Well the U joints will need to be 1330s if not 1350s. Which means a brand new shaft...
id guess a 305 t350 would be 1310 ujoints. Posted via Mobile Device
![]() Join Date: Apr 2009
http://ls1tech.com/forums/automatic-...questions.html
http://www.chevelles.com/forums/show...put+shaft+yoke This is the best web site I can give you, It list ALL the available yokes for 400 Turbos. http://www.dennysdriveshaft.com/c8_t...lip_yokes.html Desert Last edited by Desert1957; 09-06-2012 at 02:15 AM. |
I think this is the one you need to replace a bolt on yoke, with the short output shaft splines on the tailshaft.
http://www.dennysdriveshaft.com/p108...ine_th400.html Desert |
#13 |
Going to have my buddies at Drivelines nw build a driveshaft that will adapt to the trans. Eventually this th400 will be built for a 600hp bbc and have a gear vendor on it or he may go the 700r4 route. Either way we just need to get it moving though.
