09-05-2012, 11:06 AM | #1 |
69 chevy frame question
can u change a 69 frame to leaf springs? would doing that be benfichial.
09-05-2012, 11:10 AM | #2 | |
Still Learning
Re: 69 chevy frame question
Good luck. |
09-05-2012, 11:22 AM | #3 |
GMC trucks of the same year and size "usually" had/have leaf springs. Finding the whole axle, springs and hangers off one of those and swapping it all out would be fairly simple.
I always figured it all depended on what you wanted to do with your truck. The guys on here that lower their truck tend to prefer the trailing arm suspension but the guys who want to tow or haul often go for the leaf springs. |
09-05-2012, 02:45 PM | #4 |
Active Member
I've got both -68 GMC with leaf springs and 69 Chevy with trailing arms. I only noticed a slight difference in comfort level with the coil springs being smoother. But, as mentioned, if you want to do some heavy hauling leaf springs are better and it's easier to add one or two if you need to.
I should add that my GMC came with 8 leaf springs because it was a ranchers truck and he hauled feed for his cattle with it. I removed the three stiffer lower ones for more comfort since I don't do any heavy hauling.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
