Old 09-05-2012, 05:28 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
What rears in a 3/4 ton 4x4.
what diffs would a factory 1964 , 3/4 ton , 4WD, 8 lug truck have in it ? also which transfer case? >>>>>>>>>> I gotta think any 3/4 ton truck from that era would be built pretty hefty. And pretty rare to even find one. thanx , crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 09-05-2012, 11:17 PM   #2
Captainfab
60-66 Nut
Re: What rears in a 3/4 ton 4x4.
The rear end could be either an Eaton HO52 or a Dana 60. Does it have a drop out 3rd member and a round cover on the back? If so it is an Eaton HO52. The Dana 60 cover will look just like the cover on the front differential, just slightly bigger. I believe the transfer case should be the NP221.
Old 09-06-2012, 09:38 AM   #3
Should be an HO52/Dana44 Rr/Fr combo. The transfer case/transmission combo will be Rockwell T221/SM420,unless it has the standard 3spd on the column. They are very stout and not so common to find. Where is it so I can buy it?
Old 09-06-2012, 09:47 AM   #4
crossy
crossy's Avatar
tim, the truck was flipped and 75% of it is damaged including the cab. he wants too much for it i guess because he bought a crate engine 10K miles ago. I wanted it to put one of my spare cummins into, but the body is toast. i know i can sell off the engine for DECENT money, but once i found that the cab itself was damaged , i kinda wrote it off.
he wants $2500 and it's less than 60 miles from you so if you want the link let me know, thanx, crossy
98 Vortec project.
94,3500,6.5L 4L80
Old 09-06-2012, 09:37 PM   #5
Hmmm...I'm getting the hots for one,but good body parts are my main concern. I'd like an original,but I do have a newer 4wd frame/axles/drivetrain already. I'd consider it either way in better economic times,just to have the potential of building an original-ish truck.
