Old 09-05-2012, 09:43 PM   #1
70 c10
Frame swap
Wanted to see if you guys could answer some questions for me. Im new here and was thinking of buying a late 70's truck and using the frame and running gear for my 70. is this possible without major modifications. would the benifits be worth the work?
Thanks for any help
70 c10 is offline   Reply With Quote
Old 09-05-2012, 09:44 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Frame swap
stick with a '71-'72 with the disc brake upgrade....much easier
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-05-2012, 10:19 PM   #3
hahjoel
Re: Frame swap
I have a 69 with a 71 frame
69 GMC Long Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=500284
hahjoel is offline   Reply With Quote
Old 09-06-2012, 05:41 PM   #4
68GMCCustom
Re: Frame swap
Not sure why you'd want to go thru the process of "making" a different model frame fit your trucks body.
Kurt -
Old 09-06-2012, 08:50 PM   #5
hugger6933
Re: Frame swap
First off welcome to the site lots of great info on here. The frame is different. The front frame crossmember is , however the way thousands of people have converted the 67-70 trucks to a 5 lug dics brake set up in the front. The ball joint are a ton cheaper as well.WIth the engine out the crossmember swap is relativly simple to do with a little manpower for help and most of the holes line up with only a couple that need be drilled and then you can have the disc brakes with a sway bar and power steering box without having to source a bunch of parts. Do a search and look in the suspension section on the site and look at some of the threads of those that have done it. Jim
hugger6933 is offline   Reply With Quote
