Old 09-05-2012, 11:39 PM   #1
V3500KING
V3500KING's Avatar
I have some questions
First question is, what is my rear axle? I need to replace some seals and I am getting some conflicting answers of what it is. Second, I believe I have a vacuum leak. It idles high and it has no power at low rpms. I haven't been able to figure out what it is. Any ideas? Thanks in advance!
V3500KING is offline   Reply With Quote
Old 09-06-2012, 12:17 AM   #2
CentipedePerformance
CentipedePerformance's Avatar
Re: I have some questions
That looks to be a Dana/Spicer 70, assuming that the truck is the DRW in your picture. Definitely not a 14 bolt. And there are many ways to find a vacuum leak, best way is to get a can of carb cleaner and start spraying around where you think the leak is, when you hear a change in the idle, you have found it.
CentipedePerformance is offline   Reply With Quote
Old 09-06-2012, 12:20 AM   #3
V3500KING
V3500KING's Avatar
Yes it is a DRW. Thanks!! I will try the carb cleaner trick.
Old 09-06-2012, 10:26 AM   #4
spencer_41188
spencer_41188's Avatar
oh yea thats a dana 70 and good news the pinion seal, axle seals, hub seals, and the wheel berrings are all the same for the dana 60, dana 70, and the 14 bolt. silicone can be used to seal the cover, so dont look too hard for the parts because theres plenty out there.
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 09-06-2012, 04:08 PM   #5
V3500KING
V3500KING's Avatar
Thanks! Also does the dana 70 have a crush sleeve on the pinion shaft? I need to replace the pinion seal and just want to make sure I have everything before I get started. I am also going to be doing the axle seals while I am in there.
Old 09-06-2012, 04:18 PM   #6
spencer_41188
nope no crush sleeve
