Old 09-06-2012, 02:31 AM   #1
70K10Hunter
70K10Hunter's Avatar
70 front cross member
All right got another question... I have a 70 K10 4x4, the PO put a goodwrench engine in this truck, I have the W shaped exhaust manifolds on it which is bad enough but he took a torch to the front cross member cut a crecent shape to clearance the crank pulley, my actual question is are the 4WD crossmembers the same as the 2WD cross members? need to know so I know what to shop for...
Thanks in advance.
70K10Hunter is offline   Reply With Quote
Old 09-07-2012, 02:22 AM   #2
70K10Hunter
Re: 70 front cross member
Ttt
Old 09-07-2012, 02:26 AM   #3
rcbildr
rcbildr's Avatar
no they are not the same...too tired to really describe the difference.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
