![]() Join Date: Sep 2010
6 speed swap question
looking to put a 5 or 6 speed in my 72 short bed. just now starting to look for stuff. was gonna see if anyone on here had done this swap. wondering if i can still use the factory bench seat . didnt know if the trans shifter would cause a problem. anyways any tips would be great.
Re: 6 speed swap question
As far as a t56 six speed i don't think so. Tremec makes a six speed that you can change the shifter location it might work. A T5 5 speed out of an s10 will work and some people on here have done it. I have a T5 but its out of a mustang and i have bucket seats. The bench seat would be all over my shifter. do a search on here for t5 there is lots of info.
ok thanks i may just swap it to a auto but gonna be running a big cam
That's what I'm talking about T56 6 speed,That's what I'm going to be running, I've got almost everything ready to go but want to buy a new clutch & plate to put in when I start no need in putting the old stuff in when everything else is new..
Check out my build http://www.67-72chevytrucks.com/vboa...d.php?t=468622 |
been looking and it can be done now just find a trans.
Based on the FUN I have had with the T56 in my '99 Camaro SS I think trucks are going to be too much for it without the late CTS or HHR mods.
If you are still in the build/acquire stage a TH400 and a Gear Vendors OD is an awsome setup.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Fabricate till you "puke"
I have a Richmond 6 spd in my longhorn....it bolted in nice, after pulling the 400 hydro. This trans will be a problem with a bench seat,as will the T-56. I would reccomend a TKO 500 or 600 Tremec....you should have 3 options on the shifter position
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
