09-06-2012, 04:37 PM | #1 |
lowering blocks
does anybody know the measurments to fab rear lowering blocks. how wide; how long; where to drill holes and what size to drill. any info would be great.
09-06-2012, 08:33 PM | #2 |
Re: lowering blocks
Let me do a little research, I just saw a thread about a week ago on lowering blocks on the cheap, let me see if I can dig it up for you...
09-06-2012, 08:39 PM | #3 |
67-72 parts collector,…
Re: lowering blocks
7" long block.
2" wide. 7/8" holes on 4.25" centers.
09-06-2012, 08:39 PM | #4 |
Re: lowering blocks
This thread is for 60-72 lowering: http://67-72chevytrucks.com/vboard/s...d.php?t=454824
Ahh, here it is! http://67-72chevytrucks.com/vboard/s...d.php?t=196457 Home made blocks from fence post, I would contact him for more info. Good luck! |
09-06-2012, 11:01 PM | #5 |
Re: lowering blocks
thanks guys for the info.
09-06-2012, 11:02 PM | #6 |
Re: lowering blocks
09-07-2012, 11:52 PM | #7 |
Re: lowering blocks
I could measure mine in a couple of days, but I can tell you right now that it's pretty much the width of the trailing arm mount point, the same center to center pattern of the u bolt, and for length I'd make it to the end of the trailing arm, and then the same distance on the other side (front) of the block. Then the thickness is generally 2" or whatever you want it to be.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
09-08-2012, 06:42 AM | #8 |
Re: lowering blocks
This thread should give you all you need, good luck! http://67-72chevytrucks.com/vboard/s...d.php?t=541867
