Old 09-06-2012, 07:52 PM   #1
shacrm
shacrm's Avatar
22x14 rear end setup.
Hey everyone I am a newbie at this stuff, I've been a ricer for a long time messing around with hondas. Anyway I came to my scenses and started a real build, dropmember 68 with a Big Block!
My question is that I have a 12 bolt rear end that I need to shorten, I don't have my bed side pieces, does anyone run 22x14 deep lip wheels in the rear so I could get an idea on how much to shorten my housing?
any help would be appreciated!
thanks,
Shane
shacrm is offline   Reply With Quote
Old 09-06-2012, 08:36 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 22x14 rear end setup.
You gotta have your wheels first.
The backspacing of the wheels will dictate how much you narrow the rearend.
Do it right.
Buy wheels and tires first,... then measure,... then narrow the housing.
That's how the pros do it.
Too much money to guess.
Keith
Convert to disc brakes.
Old 09-06-2012, 09:04 PM   #3
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Yep, get the wheels first. I almost found this out the hard way with my 63; I wanted 3.25 b.s. and my wheel manufacturer said it would cost extra for the wheel I wanted so I stuck with 3.75 b.s and once mounted the tires barely clear due to the tire bulge and wheel lip width.
That could have been a $800 mistake for the half inch I thought I had.
If you still don't have bed sides when you get the wheels and tires, find another stock truck and measure it up. Make sure to give yourself an inch on each side more than you think. You can always run a small spacer to make up for too narrow of an axle but too wide can't be corrected without new wheels or re-re-doing the axle narrowing.
Edit: You should start a build thread so we can all see your progress.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-06-2012, 11:46 PM   #4
shacrm
shacrm's Avatar
Thanks for the info I will start a build thread shortly! These trucks have me pumped I get excited to work on it every night after work, I'm sure that will wear off after a while but I doubt it! A lot of smart people on these forums who really no there stuff. I appreciate everyone's input and help!
Old 09-07-2012, 10:08 PM   #5
502ms
502ms's Avatar
Welcome!
It does not wear off..
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 09-08-2012, 02:42 PM   #6
Jparks
Jparks's Avatar
Have you found tires to fit a 22x14 rim? I looked for those when I started putting together my next build and couldn't find any, I had to go with 24x15.
Jparks is offline   Reply With Quote
Old 09-09-2012, 09:29 PM   #7
shacrm
shacrm's Avatar
Goodyear g-force tires 305x40xR22. You said you went with a 24x15 wheel that's huge. Here's my wheels, can't decide which one!
Old 09-09-2012, 09:57 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Go with the wheel with out the chrome bolts on it.. Is that creswell oregon?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-09-2012, 10:15 PM   #9
Jparks
Jparks's Avatar
305 isn't wide enough for a 14 inch wheel
Old 09-09-2012, 10:59 PM   #10
shacrm
shacrm's Avatar
I just found that out that a 305 will only fit up to a 11.5 wide rim so I'll keep looking for a big enough tire.
Old 09-10-2012, 11:18 AM   #11
original-71
///Relaxed Atmosphere
original-71's Avatar
i know its monday but you metioned drop member and your wheel choices are off road wheels ?
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 09-10-2012, 12:33 PM   #12
shacrm
shacrm's Avatar
You can put a low pro tire on them don't let off road scare you! Lol
Old 09-10-2012, 12:50 PM   #13
LEX
LEX's Avatar
Out of your wheel options, I like the first one. Looks much less offroad. lol
LEX is offline   Reply With Quote
Old 09-10-2012, 12:54 PM   #14
Smoothride
335/30/22
Smoothride is offline   Reply With Quote
Old 09-10-2012, 02:14 PM   #15
original-71
Ive seen low pros on off road wheels just never on dropped truck, got me curious now to see this build. Any pics out there that gave you this idea
hector
Old 09-10-2012, 06:05 PM   #16
Square_78
Square_78's Avatar
I know a 24x14 requires a 405/25r24 tire. I don't think a 335 is wide enough. A 335 would be good for a 24x12.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 09-10-2012, 06:43 PM   #17
knomadd
knomadd's Avatar
14" = 355.6 mm. So for a 14" wide wheel, the narrowest tire you'll want to use is a 355.
(forgot bead thickness) A 14" wide wheel is actually 15" from lip to lip. A 385mm tire would give 15.15" tread width. 375mm = 14.76" tread width.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-10-2012, 10:42 PM   #18
502ms
502ms's Avatar
That will look good on low pros and tucked... (either) one
Best Regards,
Leon M.
Old 09-10-2012, 11:50 PM   #19
shacrm
shacrm's Avatar
I will start a build thread soon. My build will be called SINISTER, this truck will look mean sitting still. I'm shooting for a grayish silver House of Kolor paint job with the 454SS logo on the side. That paint scheme with the those big aggressive bad boyz tucked in the rear ought to set this truck off!
Shane
Old 09-14-2012, 12:10 AM   #20
shacrm
shacrm's Avatar
Would like to incorporate this into the grille.
Old 01-27-2017, 06:54 PM   #21
Custom.Chevy
Custom.Chevy's Avatar
i gotta say from reading this thread, i too am interested in narrowing my rear axle. Sounds like deciding on tires first , then ordering wheels, then narrowing the axle is the way to go. if you end up buying some odd ball custom wheel obtaining tires might be impossible. its alot easier to find the perfect tire size you want then ordering a custom wheel .... than it will be to order a custom tire.
whats the widest wheel tire combo people have seen with stock frame rails on a c10 with inner frame mounted suspension.
instagram - @custom.chevy
Custom.Chevy is offline   Reply With Quote
Old 01-27-2017, 07:04 PM   #22
Ben_Yeaton
Interesting choice for wheel, but I'm interested to see how it turns out. What about the front though? I doubt that Fuel makes anything with an offset compatible for a dropmember application?
Ben_Yeaton is offline   Reply With Quote
Old 01-27-2017, 08:29 PM   #23
BossHogg69
motor exploder
BossHogg69's Avatar
OP hasn't posted in over 4 years...
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-27-2017, 08:46 PM   #24
GR8-68
GR8-68's Avatar
I am running a 12" wheel on a stock axle, the stock 68 rear is shorter than the late 70 up axle, order the correct back spacing and you should be fine I would think
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 01-27-2017, 09:08 PM   #25
Mollzyie
Mollzyie's Avatar
Shane
Guy HAD grand ideas !
M.A.G.A.
Mollzyie is offline   Reply With Quote
