Old 09-07-2012, 03:52 PM   #1
3r!c84
Badass
3r!c84's Avatar
door. maunal to power
i need to replace my door on my truck before paint. can i use a 84 manual crank door and just put all my power window parts in it?
its a 1984
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-07-2012, 06:30 PM   #2
thepenguin99
Re: door. maunal to power
yes
thepenguin99 is offline   Reply With Quote
Old 09-07-2012, 10:15 PM   #3
3r!c84
Badass
3r!c84's Avatar
so it will work? i see that lmc dont have different doors for power and manual . so its just bolt right up all my power window stuff?
-00 Saturn 5spd
1/4:13:90
Old 09-08-2012, 03:18 AM   #4
dmartin1
dmartin1's Avatar
i always wondered this too, as id like to order power door panels if this could be done with stock junkyard parts?
manual sucks!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 09-10-2012, 05:11 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
i've put manual cranks from my 87 into my 88 so reverse should work no probs
and also all my 89 wing windows,trim, opener handles and (was) powered glass into my 78 with cranks ,
actually was one prob(older style used metal clips,newer used plastic ones)
heck you could use the manual in each till they are all set up
the switch hole becomes the crank hole,not sure if a crank hole squared out fits a switch
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
