power adder
is it possable to run a roots type blower at 5psi on my 383 stroker with 11:1 compression ratio
all i wana do is make is a flat torque curve the hp it will make is just a bonus... its a 1 ton dont wont nitrus and turbos cost more
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker. |
Re: power adder
I foresee detonation and melted pistons if you do.....
Drop the compression and up the boost. |
meowMEOWmeowMEOW
Re: power adder
realistically, that compression is going to be an issue for you, unless you decide to run a different fuel type.
If you wanted to do it with a small 144 and your existing motor, it may be doable with a methanol kit so you can still run pump gas, but you might want to consult with a local tuner, as it would be a "potent" combo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: power adder
You are in indiana. The corn fuel capitol of the world
![]() Posted via Mobile Device
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Re: power adder
well the blower bolts right to the top of the engine and theres not many choices on intercoolers, water meth injection may be the cheapest way to go
if im gana change anything it would be the pistons because there hipercraptic lol but they sell crate engines with blowers and hiper pistons and comes with a 2 year Warranty and plus your paying out $11,000 for it ... it better be good yes all the gas in indiana is e15 or e85
Re: power adder
Run E 85 and a simple meth kit is not over the top price wise.. as a back up just in case. But the e 85 is great.. make sure you have the correct items to work with that fuel though, its not very rubber friendly.
62 long box with a little SBC ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=510631 http://good-times.webshots.com/album/561798652HdwqzG |
