4spd saginaw rebuild help!!
I have a 4spd saginaw in a 66 k10, I need to rebuild in the worst way. So here's the ?, What is the best rebuild kit to get, and what else should be done at the same time? I have done a bit of research and there are quite a few companies and place to buy the kits, I just want one with quality parts. Thanks in advance!
Re: 4spd saginaw rebuild help!!
Novac
What does that mean?
![]() Join Date: Sep 2011
Novac is the company to buy from.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
Why don't you guys give him a link.
Here's one. These guys have a good rep. Look down the page for saginaw. http://www.garagemotorsports.com/muncie.htm |
That sounds like a fantastic idea!
Look on eBay, I lost my Saginaw when the retaining ring on a gear cluster broke! The broken parts chewed up the gears and the main shaft. Try looking for a "new" main shaft for a Saginaw!! Found a good used on, and gear cluster on eBay from a Trans Shop in Washington ...Main shaft was $35 and gear cluster was $10. Good Luck!
I email Novac, Eric said they don't have anything for the Saginaw and don't work with them at all. Yea Ebay is always a good idea I check periodically.
