Old 09-07-2012, 09:14 PM   #1
sigshooter
sigshooter's Avatar
coolest ground strap, check this out!
I found these while working at the scrap yard, they were off around a 1999 ford explorer. They were right behind the right front wheel going from the frame to the body.
They are super easy to get on ( and off when you find some for yourself ) require no drilling, just tap them on with a hammer. They have little spikes inside the clips that dig in to bare metal to make the connection.
I put them on my truck tonight ( one from the rear of the frame to the rear bed cross member and the other from the frame to the bottom of the cab ) and I swear the lights and signals were brighter. My truck has the battery ground going to the motor mount and then just the lil wire from the cable to the rad support screwed in behind the battery. I also installed a ground strap from my valve cover to the cab firewall ( I have seen these on 66's so I think the factory started this around then ).
I know grounding issues were a huge problem for these trucks ( melting the dimmer switch and signals and brake lights not working all the time. I think this will solve alot of problems for us.
For those junk yarders look on 99 ish Explorers ( I looked on tons of other fords and didn't find them on anything else. If I can come up with a Ford part number ( if they are available thru the dealer ) I will post it for those that dont enjoy crawling around in junk yards.
I hope this helps other members out, I know it helped my truck and it was sooo easy.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 09-07-2012, 09:46 PM   #2
piratexpress1369a
piratexpress1369a's Avatar
Re: coolest ground strap, check this out!
that is cool .great idea
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 09-07-2012, 10:07 PM   #3
Ta2Don
Ta2Don's Avatar
Thanks for the heads up
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 09-07-2012, 11:08 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
Sig, you have addressed one of the things that 75% of the guys out there building vehicles always overlook. In a 12V DC system, the ground is everything. How many times have you heard, " My car is always draining the battery", or "My headlights are really dim". You look the car over, and there's no grounds anywhere.
You MUST ground the engine, cab, and chassis!! It makes a huge difference.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-07-2012, 11:33 PM   #5
sigshooter
sigshooter's Avatar
I know it made all kinds of difference in mine. The lights are brighter, the amp meter is more stable ( doesn't bounce around as much ) wipers run faster, seems to just run better.... can't explain it all but worlds of difference.
It was sooooo easy with these ground straps
1966 Short stepside
1964 long bed
Old 09-08-2012, 06:44 AM   #6
dougf
dougf's Avatar
Wow, great info guys. I'm going to go out and ground the hell out of my truck now
dougf is offline   Reply With Quote
Old 09-08-2012, 07:12 AM   #7
clemdaddy
clemdaddy's Avatar
if you build frame-up and paint everything you have to provide even more grounds to the frame. everything to the frame. on my truck i used tons of star washers and scraped paint on both sides, lots of work. those straps of yours would have saved time and done the job.
let us know if you find them in the aftermarket...
clemdaddy is offline   Reply With Quote
Old 09-08-2012, 08:17 AM   #8
MikeS.
MikeS.'s Avatar
HAM and CB guys like me use these especially when we run some wattage. We get a much better signal and power transfer.
You might check HAM suppliers for these straps.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 09-08-2012, 01:03 PM   #9
bbadfred
bbadfred
bbadfred's Avatar
When I bought my LQ9 for my 67 shortbed I got three ground wires Battery,body.frame with the Engine. I bolted them up with star washers and I have had no problems with anything electrical old or new on the truck.
bbadfred is offline   Reply With Quote
Old 09-09-2012, 10:05 AM   #10
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
You cant have too many grounds!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-05-2012, 12:01 AM   #11
sigshooter
sigshooter's Avatar
went to the scrap yard and found the straps on 95 and 96 explorers only.... I have ordered one thru ford and will post the part number if it is correct
1966 Short stepside
1964 long bed
Old 10-05-2012, 01:39 AM   #12
Billett
Billett's Avatar
Over on the s10 forum we call them the big three. First thing I did when I got that truck. Not sure about forum rules, but if it's ok I'll post a link to that thread so you guys can check it out. The pics are using late model s10s but the concept is exactly the same.
Mods, if this is a problem please remove it as you see fit.
www.s10forum.com/big-three-big-3-upgrade-how-to
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
