Intake manifold question
Hey all, I'm putting a crate 350 in my 65 c10, and I have a question. I planned on pulling the intake from an old 350 and using it. I took it off, cleaned it up, and out of curiosity, put it on a piece of granite that I believe is flat, to see if it was flat. The part that connects to the head looks like it has a slight curve. The ends are touching, but I see a little light under the middle. Is that normal, or do I need to get it machined, or is it no good. Thanks for your help.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Intake manifold question
No that is not correct. The machined surfaces should be straight and flat.. Before you spend very much on machining those surfaces flat, compare that cost with what another good used one or a new one costs.
i'd use a good known straight edge to check just not something i "thought" was maybe straight
Thanks for the help. I'll try another route.
Posted via Mobile Device |
Maybe an edelbrock 2101 or a 2701.
#7 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
I'd get an alum. intake regardless.
I wouldnt use that factory cast iron boat anchor either way. You can get a used edelbrock alum intake for probably 50-75 bucks. It will perform a ton better than the factory piece ever did.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
C,mon guys....it has got to be good for a door stop, or a wheel chock....& yes , probably heavy enough for a boat anchor
