Old 09-08-2012, 12:37 AM   #1
IAFF2407
IAFF2407's Avatar
Air ride instal help
as Liverat can attest, wiring is my demon, does anyone have a install diagram they can pm me?
I don’t have the install directions, I HATE electrical, whom ever invented the word Ohm is sadistic, Om is for meditation – relieves stress not creates it!
Anyways, the relay harness is straight forward cause the wires are labeled. Switch box connects to the computer, easy enough. That big black coil thing plugs to the black of the computer, easy again. From the black coil of wires to the multi colored wire coil with the 4 plugs, ok, don’t know which ones to plug into on the valve assembly. For the really stressed out part is 1* the multiple colored coil of wires that plug into the computer (2 plugs) that are un-ended(made that term up), what to do? And 2* on the valve manifold those 1/8’ red inlets – would they be needed for the gauges?
3* how do I wire up for the tank (even though I haven’t decided if I’m using a tank), am I missing some wires or are those in the ball of mult colored wires, god, I need a drink now..
I’m ok with hooking the air lines (mechanical)
thx in advance
Al.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 09-08-2012, 12:47 PM   #2
canadian trucker
A day should have 30 hours.
Re: Air ride instal help
Is This is a ride tech kit?
It looks like it.
I believe if you go on their website under support or help, you can download wiring diagrams. Other wise I have a set of installation instructions at my shop.
Let me know
canadian trucker is offline   Reply With Quote
Old 09-08-2012, 02:41 PM   #3
IAFF2407
IAFF2407's Avatar
It is air ride Technologies, I have been on their site but it doesn't answer all my questions. Where abouts in BC are you?
1972 GMC Sierra
Old 09-08-2012, 02:49 PM   #4
Hart_Rod
Hart_Rod's Avatar
Looks like your missing some parts. The 1/8 red ports go to 4 pressure sensors. The pressure sensors have a wire that provide an input to the computer.
Hart_Rod is offline   Reply With Quote
Old 09-08-2012, 02:54 PM   #5
Hart_Rod
Hart_Rod's Avatar
You've got an older system. Here's the instructions you need:
http://www.ridetech.com/instructions...ssor-guide.pdf
Old 09-08-2012, 04:15 PM   #6
canadian trucker
I am in Delta.
Send me a PM if you are stuck, I'll help if you can.
I'm kinda like wiring.
Old 09-08-2012, 06:35 PM   #7
IAFF2407
IAFF2407's Avatar
Originally Posted by canadian trucker View Post
I am in Delta.
You are my new best friend, I'll send you a pm.
HartRob, thanks,....again.
Al.
1972 GMC Sierra
Old 09-10-2012, 09:05 AM   #8
BIGMIKEATRIDETECH
BIGMIKEATRIDETECH's Avatar
What you have is the E1 digital controller and Big Red valve. Your controller is missing the pressure sending units that send the pressure reading to the brain for the digital gauge. This was one of our first digital systems and is not near as advancedd as the current E3 system. The pressure senders your missing run $40 each and you would need 4 of them. You will also need a 1/8 FNPT to 1/8 Line Bulkhead to mount the senders. They are $10ea. The airline off gauge ports will then run to the senders.
I can email you the original instructions for the kit if you would like.
You can also call or email me direct with any questions. 812-481-4732 or Mike@ridetech.com
BIGMIKEATRIDETECH is offline   Reply With Quote
Old 09-10-2012, 10:44 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for jumping in Mike. Your assistance is always appreciated,
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-10-2012, 12:15 PM   #10
IAFF2407
IAFF2407's Avatar
talked to Mike this morning and on my way, thx again Mike.
Al.
1972 GMC Sierra
