dash light's stoped working ??
the other night I was getting ready to leave the wife's Grandmothers house an go to turn on the head lights like normal an the dash lights came on dim , so I go to adjust to make a little brighter an they brighten up an went out an couldn't get them to come back on ? put in new headlight switch no change , checked power to floor dimmer switch was good high an low ?? not sure whats up ? all fuses are good . what color is the wire in the plug on the back of the cluster ? any help would be great ...
#2 | |
The Older Generation
Re: dash light's stoped working ??
Fuses may be good but is there any rust in the fuse holder clips? Take a test light and test the fuses individually. LockDoc
Had same problem on my 68 , looked up the wiring diagram you can find on this site , traced it to the wire going to the dash lights from the fusebox , the terminal had broke right at the fusebox. That was mine , could be anywhere on yours! Good luck , took me some time to trace mine out.
Not a 100% sure but I think the tail lights are also on that circuit. Do you have tail lights?
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
The tail lights worked last night coming back from Lake George New york Car Show .. I will have to look up the wiring Diagram for the fuse box an start there . I will let you know When I find the Problem .
Dash light wire is grey and also includes light in heat/defrost controls. If that light works it is probably the ground wire on the dash bezel.
69 Chevy 4x4 383 Power ![]() |
laying low
![]() Join Date: Mar 2001
x2
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
