Old 05-26-2003, 02:41 PM   #1
YoSSI
Stepsides Rock!
YoSSI's Avatar
Question Where to find Transmission Gauge
Inside of the truck, the pin is missing that tells you if its on P N D R, so you just have to count and feel if your in drive. Where could I find a replacement Pin/ guage? (Store, catalogue..etc)
Thanks!
1987 GMC Sierra Classic Stepside. 305, Flows, more mods in the future....
http://www.cardomain.com/id/yossi316
YoSSI is offline   Reply With Quote
Old 05-26-2003, 04:33 PM   #2
76bonanza
76bonanza's Avatar
I got one from my chevy dealer about 5.00 bucks for just the pointer.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-26-2003, 06:17 PM   #3
Russell
Professional Grade
Russell's Avatar
YoSSI, my truck had a similar problem which is very very easy to fix by yourself with only a phillips screwdriver
That little pin moves becuase it is directly attached to your shifting bar, when you move the bar, you move the little pin. Now, what seems to happen often is that the string that attaches the pin to the shifting bar breaks, all you have to do is take off your dash console cover and you'll instantly see what I mean, just retie the string and use a small peice of wire to reattach it to the little loop that is attached to the shifting bar (not the bar itself by the way, I mean that whole round assembly that moves) Chances are your little pin isn't actually missing, just has been pulled off to the left by the little spring to the point where you cannot see it.
Hope this helps!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-26-2003, 09:07 PM   #4
YoSSI
Stepsides Rock!
YoSSI's Avatar
Thanks for the info!
I'll tryo to fix it in the next couple of days!
Old 05-28-2003, 02:29 AM   #5
the baron
the baron's Avatar
wire snapped on my truck too
didn't fix it already , minor breakdown , truck still driving , will fix it , dunno when , will see , should change the whole thing , as the needle shifts hardly , worn out , truck must have a lot of miles in the wheels , dunno how many , don't care...
The Baron
___________________________________________________
1979 C10 LWB , 350 Olds engine
1977 Impala sedan , 250ci , "Ye Old Reliable"
1960 girl friend , frame still good , body has some dents
the baron is offline   Reply With Quote
