Old 09-08-2012, 01:53 PM   #1
79 blue monster
79 blue monster's Avatar
8 lug to 5/6 lug
my truck is a 3/4 ton thats static dropped. im having a very hard time finding wheels that are the correct offset, with, size. i lowered a 3/4ton because i wanted it to be unique rather than a 1/2 ton. since i cant find any wheels that i like(or fit), i was wondering if i can keep the 3/4 suspension but drill out the 8lug pattern to a 5 or 6 lug pattern. the only thing is, i dont know if a 5/6 lug pattern can fit over the center hub on a 3/4 ton axle. any help/opinions apreciated.
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
Old 09-08-2012, 02:20 PM   #2
tinydb84
tinydb84's Avatar
Re: 8 lug to 5/6 lug
There are conversion drop spindles. You keep everything except the spindle and brakes. In the rear they make 5 lug hubs. $400 bucks.
Old 09-08-2012, 03:35 PM   #3
wwj75c30
wwj75c30's Avatar
dont convert it to 5 or 6. it was made a 3/4 ton so i say keep it that way you gotta be different
75 c30 silverado drw 454/th400hd d70 soon to have d60 up front
73 c20 custom deluxe sm465 14bff parts truck
wwj75c30 is offline   Reply With Quote
Old 09-08-2012, 04:17 PM   #4
Liddy71
Liddy71's Avatar
hope someone puts some input on this i have 3/4 that i want to lower and was wondering on lowering and what wheels and tires to run
Liddy71 is offline   Reply With Quote
Old 09-08-2012, 04:17 PM   #5
79 blue monster
yeah i dont want to buy drop spindles again. i already spent $400 on mine. the problem is the wheels that will fit and do look really nice are over $2000! so i just thought that maybe converting it to 5/6 lug would be cheeper but it doesnt look like its going to be.
Old 09-08-2012, 05:15 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Your gonna have to change spindles and the rearend at a minimum.
No redrilling will get it done.
Spending more money is your only option.
A donor truck might make things cheaper.
Keith
Convert to disc brakes.
