1983 Chevy 350 engine idle issue
I have a 1983 Chevy C 10 with the 350 in it. It ran fine up until yesterday, when at the parts store it started to die at idle. Got it home, and today found that the truck will not run at idle. It will start when throttle is increased, however it runs rough, and the exhaust emits gray/black smoke. As soon as throttle is released, the engine immediately dies. I changed the spark plugs, checked the fuel filter, and i am stumped. The carb is still squirting fuel. The number 1 and 3 cylinder spark plugs had some deposits on them, but not much. I need some help here, thanks for your time.
Re: 1983 Chevy 350 engine idle issue
Were the plugs soaked with gas? Sounds like the carburetor is flooding the engine, when was the last time it was cleaned and rebuilt?
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Yes, the plugs were soaked in gas. I'm not sure how long ago the carb has been worked on, cleaned, or rebuilt. If that needs to be done, do you recommend shipping it to someone to have it done? It's a Holley, usure of which model exactly. I've just been getting into these trucks for fun, and am still pretty novice at it. Let me know what you would recommend. Thanks for the help.
Easiest/cheapest things first. Check for vacuum leak by using carb cleaner or propane. Carb cleaner with cool engine only please. Youtube video I found
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
| Bookmarks |
