Old 09-08-2012, 03:31 PM   #1
MisterE72
Keep Your Nose Clean
How how did you run your Vintage Air hoses?
Hello folks, i'm looking to see how you guys ran your vintage air hoses through your firewall (or other) and the bulkhead you used. Post pics if u can. Thanks
MisterE72 is offline   Reply With Quote
Old 09-08-2012, 05:04 PM   #2
Lee H
Lee H's Avatar
Re: How how did you run your Vintage Air hoses?
I'm using the bulkhead for the fire wall that my Vintage air kit came with. Did yours not come with one or are you looking for other options?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have all original numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-08-2012, 07:00 PM   #3
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Well, this probably isn't for *everybody*, especially the show guys. But I wanted a little "design
balance" to that big brake huffer on the driver's side.
And, I don't have the fabbing expertise that some folks on the Forum have.
I like the one VA sends...it's a lot of plastic, but really is unobtrusive when you paint it.
If I had the skills, for my money, the best setup would be a shaved firewall with the bulkhead
fittings that VA sells. Oh, second to running everything thru the fenders where you can't see 'em at all.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-08-2012, 07:49 PM   #4
gotchamel
No bulkhead fitting,just attatched them to the hard lines from the evaporator.Stubbed off the heater hoses,not really in a cold climate.I routed the hoses behind the fender panel and came out under the battery instead of across the wheel well.Alot cleaner look.Had to shorten the small line from the dryer to make the connection.
gotchamel is offline   Reply With Quote
Old 09-08-2012, 10:08 PM   #5
gearys 5600
gearys 5600's Avatar
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 09-09-2012, 01:07 AM   #6
ItsRandy
ItsRandy's Avatar
Bulkhead fitting.
ItsRandy is offline   Reply With Quote
Old 09-09-2012, 08:29 PM   #7
MisterE72
Hey Geary, did you run your hoses through the fender?
Old 09-09-2012, 08:32 PM   #8
MisterE72
Does it matter where on the firewall you run your hoses? Im noticing from the pics you guys are placing the bulkheads in different locations.
Old 09-09-2012, 09:13 PM   #9
gearys 5600
Mine are ran under the fender, and they come back out under my battery tray. Very simple and looks alot cleaner. IMO.
1956 chevy nomad
Old 09-09-2012, 09:23 PM   #10
MisterE72
Geary, can you take a couple more pics of how you ran the hoses? Thanks
Old 10-01-2012, 08:38 PM   #11
ffk
ffk's Avatar
any pics from under dash?????
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline   Reply With Quote
Old 10-01-2012, 10:41 PM   #12
Cg1968
Subscribed
Cg1968 is offline   Reply With Quote
Old 10-01-2012, 11:31 PM   #13
j1970GMC
I used the plate that came with the Vintage Air kit...
j1970GMC is offline   Reply With Quote
Old 10-01-2012, 11:37 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
Check out big al 71's thread for almost hidden lines...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-01-2012, 11:57 PM   #15
Chvy2NV
Subd
Chvy2NV is offline   Reply With Quote
Old 10-02-2012, 12:09 AM   #16
SactoJim
SactoJim's Avatar
Here's mine.....I just painted the plastic cover the same color as truck and spent a bunch of time getting the lines to fit nicely.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-02-2012, 12:37 AM   #17
longbed67
longbed67's Avatar
Used a metal punch and punched through I have my kit mounted very high in the dash and moved slightly over for more functional in cab space which is the cause of the placement of the lines
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 10-02-2012, 03:57 AM   #18
Beetle
Beetle's Avatar
You have a link? I couldn't find any member by that name and plane ole big al only has one post or maybe I'm just blind...
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
Old 10-02-2012, 07:19 AM   #19
longbed67
longbed67's Avatar
http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
Here ya go man! Let him be of some inspiration to you!
Adam
(608) 214-8706
Old 10-02-2012, 11:18 AM   #20
magwakeenercew2jh
And fit nicely, they do!!!
A shaved firewall, a/c bulkhead fittings, and/or hiding the all the lines and the fittings are very sweet.
But for my taste, the REAL difference is in plumbing the lines around the compressor in order to route them to a more "tucked away" spot than I have mine.
Later for me for that. But it will happen in the future. Inspired by SactoJim.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 01-14-2013, 06:15 PM   #21
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
Wink Re: How how did you run your Vintage Air hoses?
Originally Posted by gearys 5600 View Post
that is nice
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 01-14-2013, 06:56 PM   #22
thesledhead
thesledhead's Avatar
I just used the template they sent me with the kit to mark the holes.
thesledhead is offline   Reply With Quote
Old 01-15-2013, 06:07 PM   #23
ffk
ffk's Avatar
hey did the template have measurements on where to put template???..im trying to fiqure out where to drill holes before i paint cab...
Attachment 1041468
Attachment 1041469
Old 01-28-2013, 04:02 PM   #24
ffk
ffk's Avatar
Old 06-23-2013, 08:57 PM   #25
elf w/capital T
Super nice!!!
elf w/capital T is offline   Reply With Quote
