09-08-2012, 07:53 PM | #1 |
I6 230 truck & Nova II same?
I have a chance to pick up an I6 230 out of a 1965 Nova II. Are the truck & car engines the same?
Thanks Larry |
09-08-2012, 08:11 PM | #2 |
Re: I6 230 truck & Nova II same?
They might be the same size but I am guessing the nova engine will be down on some HP and torque.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-08-2012, 09:15 PM | #3 |
Check the oil pan. Sump could be on the wrong end for a swap. Might need to swap it.
09-08-2012, 09:37 PM | #4 |
Geezer you are right. It is backwards from the truck.
Thanks Larry |
09-08-2012, 11:15 PM | #5 |
60-66 Nut
Also check for the presence of the boss for the clutch bellcrank ball stud
09-09-2012, 05:06 PM | #6 |
If you use the pan & pickup off the other engine there wont be a hole for the dipstick tube. Make sure the Nova engine is a 230. Most of those were 194 s.
09-10-2012, 10:39 AM | #7 | |
Larry |
09-10-2012, 05:11 PM | #8 |
The sump on the engines are in different locations between the two configurations. The sump is in the middle on the Chevy II, and at the end (near trans) on a truck. The bolt patterns are the same on both oil pan models. It could be a 194 engine in the Chevy II, but that's a good thing, 194 have steel cranks, 230 is cast iron. "IF" the Chevy II engine comes with a bell housing, it won't work with the truck clutch linkage. The throw-out bearing arm is positioned at 9 o'clock (like most Chevys in the truck) BUT on Chevy II's it's at 7 o'clock. (It would be a good trading piece IF your into that type of thing)
