Old 09-09-2012, 12:24 AM   #1
stocker96
stocker96's Avatar
how to recharge A/C 96 silverado
So, I've reached the last repair before doing modifications to my 96. Air conditioning, mine blows semi cold barely colder than my vents. how do i recharge it?
stocker96 is offline   Reply With Quote
Old 09-09-2012, 12:56 AM   #2
BarryB
BarryB's Avatar
Re: how to recharge A/C 96 silverado
I see your from alaska what parts store do you have available where your at??
Sounds like to me all you'll need is a can of freon, You can get some that has all you need to recharge your system. some like the one in pic. you hook it on start truck turn on A/C. Pull trigger on can until desired pressure is meant. Which it will tell you on the can what a good PSI is for you.
Hope that helps.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-09-2012, 01:52 AM   #3
stocker96
stocker96's Avatar
Thankyou Barry! We have Oreillys NAPA and Autozone I'm sure ill find something. now I cross my fingers and hope I don't have a leak.
Old 09-09-2012, 05:51 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Watch out for leaking Schrader valves....you'll see the oily residue at the charging ports, if they're leaking like mine were. The guts are replaceable, but the normal tool, similar to a valve core tool for tires, doesn't fit within the ports. I'm sure it is available at the parts store.
Member Nr. 2770
Old 09-09-2012, 07:04 PM   #5
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Hope that helps.
NO NO NO NO!!!!!!!!
Have a professional shop pull a vacuum on your system and then they can put in the specified amount of R134.
ProStreet68SB is offline   Reply With Quote
Old 09-09-2012, 08:11 PM   #6
Big Block 454
Big Block 454's Avatar
If it's low on refrigerant, it had to go somewhere.
Big Block 454 is offline   Reply With Quote
Old 09-10-2012, 02:48 PM   #7
Jeepwm69
Dad's 95 did that last year. Put a can of R134 in there and it's been blowing cold ever since.
My 2001 4runner needed a can about every 3 years, but would blow cold for 3 years before I had to add another.
The PROPER way to do it is to drive to a shop and have some cerified blahblahblah charge you $1000 to fix it.
MY way to do it is to get the can of freon above, add a can, and see how long it blows cold.
If it leaks out after a few weeks or quicker, find the leak and fix it.
If, as in both of my cases, it blows cold for a year + with a can of freon, just throw a can in there every once and awhile and be done with it.
Jeepwm69 is offline   Reply With Quote
Old 09-11-2012, 12:03 AM   #8
stocker96
stocker96's Avatar
i should correct myself, obviously it has a leak, I'm going to hope it doesn't have a *major* leak. I will not pay rediculous shop fees, $120/hr is the cheapest for AC in my area.
