Old 09-09-2012, 07:21 AM   #1
kgmunro
Air cleaner clearance
What are people using for stock looking air cleaners on their trucks that have a 230-6 cyl with a power brake booster ? I added power discs to my 65 and only have a small amount of clearance from the booster to the carb (about 5 inches). I want a stock frying pan style air cleaner if possible.
kgmunro is offline   Reply With Quote
Old 09-09-2012, 08:56 AM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Air cleaner clearance
On my 65, I used a 4" air cleaner because of the space. I didnt have power brakes on that truck so I could have gone bigger.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-09-2012, 09:18 AM   #3
sigshooter
sigshooter's Avatar
I used stock the stock power brake setup with the factory alum. wedge spacer. Chevrolet designed this becuase of the air cleaner clearance issue.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 09-10-2012, 12:01 AM   #4
Captainfab
60-66 Nut
Starting in '67 GM used an offset air cleaner on the I6 trucks equipped with power brakes. You might try looking in the '67-'72 classifieds here on the forum. They are not very easy to find, but they do pop up every now and then. Otherwise you might look into a 8-9" K&N air cleaner assembly. I had one of those on my '63 4x4 Suburban with the 292 and power brakes.
