Old 09-09-2012, 10:45 AM   #1
murr
fuel gauge
Need help, changed over from dummies lights to the gauges, noticed I had to change some wires around on the plug. My fuel gauge still won't work, put new gauge in and sending unit.
murr is offline   Reply With Quote
Old 09-09-2012, 01:52 PM   #2
70K10Hunter
70K10Hunter's Avatar
Re: fuel gauge
might check the wire from the sending unit to the fuse panel, use a multi meter and check for continuity, the wire runs under the sill plate and that is a very harsh environment under there.
70K10Hunter is offline   Reply With Quote
Old 09-09-2012, 02:56 PM   #3
FirstOwner69
FirstOwner69's Avatar
Re: fuel gauge
Did you follow these rewire instructions?
http://www.gmcpauls.com/Tech%20Tips1.htm
FirstOwner69 is offline   Reply With Quote
