ready for reassembly
back-up lights
My back-up lights work, but they only work when the tranny is in NEUTRAL!!! Is my switch screwed, or is the linkage just out of adjustment?? It's a th350 trans. Thanks
jason ![]()
stock 71 4x4 2003 Jeep Liberty, rocky mountain edition I'm obsessed, and wouldn't have it any other way! |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
If it is a coloum shift you need to adjust the switch on the colum. Just unlosenhe screw and rotate the switch untill the light's come on in reverse. You can put the shifter in reverse and rotate the switch untill the light's come on... Hope this help's you out.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
PROJECT 7DEUCE
Also make sure the truck still stay's in park this is also how I backed my blazer threw the house!!!!!!
thanks. I didn't realize the switch it self was adjustable. I 'll give that a try on the weekend.
