Unknown frayed/unconnected wire help
Crawling around under my truck today I found one wire with a blade connector on the end (I'd say an 18g stranded wire) frayed and only holding on by two strands. It was not connected to anything. Right next to it was a "female" connector also not connected to anything. One would assume they connect to each other, but I have no idea what they're for. I traced the wires back as far as I could and they seem to run up into the bundle in the rear hood rain gutter.
In the picture I'm laying under the truck looking forward and up into the engine on the passenger side. Help!! |
Re: Unknown frayed/unconnected wire help
Come on guys. Nobody has a clue???
what year of truck and what trans also color of wire
Fuzzy |
72 350CI/THM350. The wire appears to be black.
Blower motor?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
The green female spade wire is very likely a temp sending unit, if you already have a gauge, it will turn on the idiot light on the cluster. That sender is on the block just above the starter under the ran horn exhaust manifold. You might have just a a plug in the block where the sending unit would go. The gauge wire (if you have one) usually is either going to a sending unit in the intake manifold under the top radiator hose or in the block between 1 and 3 cylinders. The other looks like a heater fan connector (??) but without seeing the inside of the connector it is hard to tell. VetteVet has posted wiring diagrams that are very useful, have you tried searching the forum? I am not on my other computer that I keep all that stuff on or else I would track it down for you. Good luck! G.
Thanks GuyO. I've yet to see any temp lights on the dash. I get a brake light when starting the truck, but nothing else. So I'm thinking you're right. Everything else on the truck works. I'll check the wiring diagram and fix and trace the frayed wire tomorrow...
No problem. That spade wire is most likely green even though it looks black. The other connector is on the wrong side to be transmission IMO. I have both a Powerglide and TH350 on the floor in the shop and they connect on the drivers side.
Have you checked to see if the wires are for the TCS (transmission controlled spark) system. It use a trans switch on the right side of the trans and a temp sender on the right side of the block that connect to a left firewall relay. Do a site search or better yet thumb through the factory manual for a full rundown.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
