09-09-2012, 04:19 PM | #1 |
round or rectangle mirrors on 67 c10
For the life of me and this may be real simple. How can I tell if my 1967 C10 came with rectangle or round mirrors? It is a CE10934 w/base 127 fleetside.
09-09-2012, 04:48 PM | #2 |
Active Member
Re: round or rectangle mirrors on 67 c10
If it does not say on the spid that optional mirrors were ordered, I'm pretty sure that a C/10 came with the standard round mirror.
09-09-2012, 04:57 PM | #3 |
thank you ... I do not have an option for mirrors on my spid. But I do have 2 custom group options 4Z61DP and 4Z62AG. Not exactly sure what is in those options.
09-09-2012, 06:13 PM | #4 |
67-69 was round mirror from what I have seen. 1970+ is square. LMC catalog says the same thing i believe. I ordered some round 69 mirrors from LMC for my 1970 GMC. I think the round mirrors look better personally.
09-09-2012, 06:29 PM | #5 |
That is what I bought for my 69 as I thought they looked better as well, one draw back is they are not very big so you cant see a lot out of them kinda wish I had bought the larger square ones now.
Posted via Mobile Device |
09-09-2012, 07:00 PM | #6 |
When I found my 67 it had a larger rectangle mirror on the driver side and a smaller round one on the passenger side. They were both broken so I put on a new rectangle and round. Also my spid says something about an aux mirror?
You can't see much out of the little round one. It's better than no mirror but doesn't seem like much compared to the rectangle.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
09-09-2012, 07:36 PM | #7 |
Active Member
Some early models came without rear view mirrors inside the cab and installing one was an option. Round outside mirrors were the standard issue unless otherwise specified. I have the round mirrors on both of mine and haven't had problems with visibility since I have the large rear window. The blind spots may be more of an issue with the small rear window on your 67.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
09-09-2012, 07:40 PM | #8 |
my 67 came 2 me without now it has square I want 2 see everything
09-09-2012, 07:43 PM | #9 |
Yes I have the small window. Maybe that's why I prefer the larger mirror.
