Old 09-09-2012, 05:40 PM   #1
ol_skool_chevy
ol_skool_chevy's Avatar
700r4 crossmember
I have a 1966 truck with a 230 ci inline in now with the stock truck granny trans in it.
Im getting ready to put a new 327 small block in it with a 700r4.
I want to try to have everything al together before I start but the only thing Im not sure about is my trans crossmember. i shopped around amd found alot for sale but im seeing straight, 2 inch drop, 3 inch drop. Im not sure what one to order without the motor and trans in the truck..
Im sure alot of you have put 700r's in your trucks...what crossmember did you use?
I could just make one but seems just as easy to buy one that looks nice.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 09-09-2012, 06:19 PM   #2
bama63
bama63's Avatar
Re: 700r4 crossmember
i used this one http://www.classicperform.com/NewPro...9427-Large.jpg about 79.00 and i only had to drill one hole on each side
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 09-09-2012, 06:36 PM   #3
Indian113
Indian113's Avatar
I bought the same one when I put my 350 in,I just moved it back and drilled a new hole too for the 700R4. It fit's great for the money
Indian113 is offline   Reply With Quote
Old 09-09-2012, 06:54 PM   #4
rbar
rbar's Avatar
Same here. Worked great.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 09-09-2012, 06:56 PM   #5
ol_skool_chevy
thanks guys....hate to buy the wrong stuff
its like a Gun ...better to have it and need it then need it and not have in
Mark with Chalk
Cut with a torch
Old 09-09-2012, 09:07 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Used a stock automatic crossmember. One was already in my 66 and the one in the 65 came out of a 67.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-09-2012, 09:16 PM   #7
Andyboy
Andyboy's Avatar
Do those fit the 60-62 gmc trucks also?
Andyboy is offline   Reply With Quote
Old 09-10-2012, 01:23 AM   #8
Captainfab
60-66 Nut
This is what I would do. You just need an auto trans crossmember from a '63-'87 truck. You'll just have to drill the holes to bolt it in once you get the location. You would still have to do that with an aftermarket crossmember.
No. To my knowledge, no one makes a aftermarket trans crossmember for the '60-'62 trucks. If you buy one, it will need to be cut down to fit in between the X-member in the middle of the frame. The '63 and up trucks do not have than X-member in the frame.
Old 09-10-2012, 01:30 AM   #9
ol_skool_chevy
Mark with Chalk
Cut with a torch
Old 09-10-2012, 01:51 AM   #10
padresag
http://www.persh.org/pickup/700R4.htm
ron
padresag is offline   Reply With Quote
Old 09-10-2012, 10:06 AM   #11
Chevy Fleetside
Yeah.,. The stock crossmember will not work. Didn't relized it was a X frame. sorry.I think the frames are wider.
Old 09-10-2012, 01:05 PM   #12
ol_skool_chevy
Thats what I like about Captainfab, He's the wikipedia of trucks.....
As Joe Friday always say “Just the facts ma’am, just the facts.”
Thanks for your help..........
Mark with Chalk
Cut with a torch
Old 09-10-2012, 04:06 PM   #13
ol_skool_chevy
Are the 63-87 auto trans crossmemebers bolted in stock or do they have rivets??
Im getting ready to go to the pick and pull to get one..
Mark with Chalk
Cut with a torch
Old 09-10-2012, 04:18 PM   #14
padresag
they are bolted in, so as to make taking an a/t out easier
ron
