Old 09-09-2012, 08:32 PM   #1
2772
2772's Avatar
Mystery Diagnosis.
Battery has juice. Tapped the starter and still didn't start. Was running fine day before. Did rain last night. Any guess why it wont start?
FEEL, FEEL, FEEL , FEEL MY HEAT!
2772 is offline   Reply With Quote
Old 09-09-2012, 08:38 PM   #2
JCD
JCD's Avatar
Re: Mystery Diagnosis.
In the few times that's happened to me.. it was always a poor connection of the secondary wire coming off the positive, that goes across the rad support to the ignition.
May not be your problem, but a good place to begin.
J
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
Old 09-09-2012, 08:39 PM   #3
jocko
jocko's Avatar
If it rained HARD... check for hairline cracks (or worse) in the distributor cap. They can let moisture in and cause it to not start.
If you're not sure, take off the cap, blow dry it, then re-install and see if it starts. Sounds stupid, I know - happened to me though. Truck kept drowning out over puddles, and this turned out to be the problem.
Old 09-09-2012, 08:43 PM   #4
2772
2772's Avatar
OK. About to try it right now
Old 09-10-2012, 03:17 AM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I had the module go bad then I had the rotor button have a hole in it then after a new rotor button i forgot to thook a wire up and BOUT NEVER figured that one out
John
1999 Toyota Tacoma 4x4
Old 09-10-2012, 06:39 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
I also hit the inside of the distributor cap with WD-40. The L6 design, with the distributor on the side, is prone to shipping water when splashing thru intersections and fording wet draws.
Check your battery terminal connections. Wet weather can hasten corrosion of the terminals and leads.
Old 09-10-2012, 08:37 AM   #7
trucks72
trucks72
trucks72's Avatar
Could be neutral safety switch.
trucks72 is offline   Reply With Quote
Old 09-10-2012, 09:34 AM   #8
gerfunken
gerfunken's Avatar
Every once and a while, the starter lead on the back of my ignition switch works out a little bit. The first time it happened it stumped me for a while. Now, I think of it as a kill switch.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 09-10-2012, 09:50 AM   #9
cdowns
cdowns's Avatar
remove both battery cables and clean all 4ends and where they mount reinstall cables
Old 09-10-2012, 10:45 PM   #10
cableguy0
Problem solved. Issue is in the column. Hes a local firefighter and the truck landed at my shop. Hung A proper exhaust not now working out other issues.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-10-2012, 11:16 PM   #11
2772
2772's Avatar
Yeah he's right, the selector on the column is off track. It was just as simple as giving it a little nudge to make sure it was all the way in park and vroom I was off to the races again.
