Old 09-09-2012, 09:05 PM   #1
gotchamel
Exaust through sport bumper?
I would like to cut half round holes in my sport bumper and have exaust come out there,any pics or input?Any way to cut holes w/o having to rechrome due to heat?Thanks.
gotchamel is offline   Reply With Quote
Old 09-09-2012, 09:47 PM   #2
29od1
Re: Exaust through sport bumper?
Figure out the hole size you need and get a bi-metal hole saw the correct size. You can use your drill and take your time and it shouldn't generate much heat at all.
Just make sure to use some high temp paint (like VHT high temp header paint) around the edges of the hole or it will rust.
29od1 is offline   Reply With Quote
Old 09-09-2012, 11:38 PM   #3
PHAT TONY
PHAT TONY's Avatar
I thought about doing this but using an old new dodge truck rear bumper for the cut outs.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 09-09-2012, 11:45 PM   #4
jablack
Classic Chevy Recycler
jablack's Avatar
I had the same idea. I just don't want any other brand parts on my Chevrolet. I was looking mine over the other day wondering how it would look with cut outs in the bumper.
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
Old 09-10-2012, 05:10 PM   #5
gotchamel
yNot sure a hole saw will work,trying to get a 1/2 round hole.Seen it before on some muscle cars and I like it.Maybe a steady hand and a plasma cutter,mainly curious if the chrome can withstand the heat.
Old 09-10-2012, 05:56 PM   #6
Square_78
Square_78's Avatar
The chrome will turn blue like a motorcycle exhaust pipe if u heat it too much. You could use a big hole saw and them touch up the paint. The chrome might still chip though. It would most likely have to be rechromed to keep it from rusting and chipping. If you can get away with just painting the edges then you will be lucky. Depends on the quality Of the original chrome job.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 09-10-2012, 06:03 PM   #7
chet
cover the whole area with green masking tape. layout your lines and use a zig saw with a super fine blade. leave a bit of the line and die grind up to it. then paint it while the tape is still on. maybe some spray on galvanizing would work good on the edge.
chet is offline   Reply With Quote
Old 09-10-2012, 06:07 PM   #8
truckster
truckster's Avatar
The problem is that he wants HALF a round hole - can't do that with a hole saw. I think you're going to end up re-chroming your bumper if you cut it, because the chrome is likely to get very discolored and might want to flake away from the steel underneath.
They make carborundum blades for jigsaws and sawzalls, but I've never tried them on chrome.
truckster is offline   Reply With Quote
Old 09-10-2012, 06:42 PM   #9
gotchamel
10-4 on the "not being able to use a hole saw"Truckster.Nowhere for the pilot bit to bite on a half round hole.Thanks for the taping idea,its a repro sport bumper so my thoughts are the chroming is subpar.Maybe someone has a pic?
Old 09-10-2012, 06:46 PM   #10
cdowns
cdowns's Avatar
i'd check the cost of replating your bumper b4 doing anything
i'd think just cuttin the hole will b it for the original chrome// not to mention to just cut a hole with no finishing will look gunky and hacked
Old 09-10-2012, 06:48 PM   #11
gotchamel
Yep,it will need a rolled lip.Getting expensive isnt it?
