Old 09-09-2012, 11:44 PM   #1
arturo7
arturo7's Avatar
Max Tire Size?
Will 30 or 32 inch tires fit under my 59 panel at the standard ride height? What did these trucks ship with, 28s?
thanks
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 09-10-2012, 12:30 PM   #2
mr48chev
mr48chev's Avatar
Re: Max Tire Size?
Stock height you can probably run them but you might run into issues if the truck is lowered a lot. on the 57 panel I had in the mid 70's it seemed like the clearance to get a tire in and out of the wheel wells on the back was a bit tight for the tires I had then and I think those were L-78 15 tires intended for a Cadillac at that time period.
mr48chev is online now   Reply With Quote
