Old 09-10-2012, 08:15 AM   #1
OniDII
OniDII's Avatar
Brake decision...
Trying to get opinions on brakes... Do I stick with the original drum/drum or upgrade to power disc/drum or the full monty power disc/disc?
I really see no need for changing out the rear... this is a daily driver nothing crazy under the hood just a 283 maybe in the future might swap to a 350. I am not driving highways or high speeds.
Any opinions...
OniDII is offline   Reply With Quote
Old 09-10-2012, 08:53 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Brake decision...
I would swap to the disc in front.The drums work fine but in traffic they do tend to fade.Obviously power is nicer for pedal pressure and unless it's a show truc where you don't want a booster cluttering up under the hood,it just makes sense.So I vote Power disc/drum.It's a simple enough swap,but keep in mind,it widens the front track by 3/4 in each side.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-10-2012, 09:03 AM   #3
ramrod7373
I coverted mine to power disk. Got the whole kit from CPP. They have the whole kit in a box. Pretty easy to do.
ramrod7373 is offline   Reply With Quote
Old 09-10-2012, 09:34 AM   #4
68gmsee
Active Member
68gmsee's Avatar
It all depends on how much work you want to put in it and how much money you want to spend. The front disc conversion would the best option. The second would be a complete rework of the drum brakes system including a power brake booster. I wanted to keep my 68 GMC as original as I could so I redid my drum/drum brakes and they work really well for the little driving I do.
To give you an idea on cost I spent about $300 for new shoes, turning all the drums, new brake cylinders, all rubber hoses, master cylinder and booster. This was about 2 years ago, and from what I see the cost of parts have gone up considerably in the last two years.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-10-2012, 10:19 AM   #5
steelhorse
steelhorse's Avatar
I like the disc /drum option for a daily driver.You can even hit a scrap yard and get parts from a 73 up to save on cost.
steelhorse is offline   Reply With Quote
Old 09-10-2012, 10:38 AM   #6
truckster
truckster's Avatar
Having had both, I love the consistent stopping power of power disc/drum. The rears do the lesser part of the stopping, so I don't see the need for discs back there, and that's a lot more work and expense.
truckster is offline   Reply With Quote
Old 09-10-2012, 02:21 PM   #7
davepl
davepl's Avatar
I'd vote disc/drum. I did a full-disc conversion on my '69 2+2 (think Impala) and have had nothing but misery from it. No idea whether it's a mismatch between the master size and the Cadillac rear calipers or what, but it sucks.
I just retrofitted front discs to my '70 drum-drum truck, but used all factory parts from a '72 disc brake equipped truck. I'm a big fan of matched systems.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-10-2012, 04:39 PM   #8
OniDII
OniDII's Avatar
Thanks for all the suggestions... I will continue with the drum/drum until winter when I take it off the road and over the winter will most likely go power disc/drum.
1967 Chevy C-10 fleetside
