Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-10-2012, 09:40 AM   #1
Marv D
Registered Truck Offender
Marv D's Avatar
Almost back together
3 pistons, (how the hell does 2 screws destroy 3 pistons???) 4 valves, $400 in head welding / guides / milling repair, touch hone block, rings / bearings / gaskets.. normal freshing stuff.. I'm at $2900 not counting time and gas to run things 75 miles to and from the machine shop.
Lesson learned: make shure those damn squirter screws have a touch of locktite on them, and check them FREQUENTLY anyways!!!
This motor IS posessed!!!!!!!!!!!!!!!!!!!!!!!!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-10-2012, 10:49 AM   #2
chevytruck1970
chevytruck1970's Avatar
Re: Almost back together
You should dyno it after its back together maybe it wouldn't make 666 this time
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 09-10-2012, 01:02 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
I started mine to pull it off the trailer sat and it had a strange whisle . Looked down the carb and there was a leaf in it . Thought about your squirter deal .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 09-10-2012, 02:37 PM   #4
Super73
Super73's Avatar
Glad to hear it is getting some love, but man, those are some expensive screws. You'll be back at it in no time.
I would be very interested in a chassis dyno number from it.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-11-2012, 11:02 PM   #5
Marv D
Marv D's Avatar
She is making noise. Have a ADRA race friday night Truck is ready!!!
If Rich doesn't tech I'll go off the stop again and see if the machnist 'trick' valve job helps or hurts LO. Has just a touch more compression (from milling the heads now 13.7 instead of 13.5). Because I'm not spinning it up and the convertor is a bit tight,, I put 1.5 more degrees advance in the cam this time.
Now just have to make 3 races and it will be Dune season again.
Old 09-12-2012, 01:31 AM   #6
Super73
Super73's Avatar
Marv, I know it is more money, but man, I bet that thing would like E85 Might be more consistant too in the heat.
Old 09-13-2012, 08:51 AM   #7
bigboybodry
bigboybodry's Avatar
can't wait to see some video!
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 09-16-2012, 08:15 AM   #8
Marv D
Marv D's Avatar
Welp, 10.786 @ 121.5 in 3400' air. Picked up a litle MPH and the 60' is now as good as my Nova was when it was a 10.5 package. 1.43 sixty is rather surprising to me. This thing is not that well set up. Unfortunately I dialed 10.79 on that 10.78 pass so it was a short night. But the ol girl is back doing her job. Now it's time to start getting the sand rail ready for November
