Old 09-10-2012, 10:37 AM   #1
big d's red67
big d's red67's Avatar
Instrument bezel lens removal
I need to know how to get the lens out of my bezel, is there an esay way to do this?
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 09-10-2012, 11:30 AM   #2
chevy2tom
chevy2tom's Avatar
Re: Instrument bezel lens removal
Nope, drop the steering column & pull the cluster.
chevy2tom is offline   Reply With Quote
Old 09-10-2012, 11:40 AM   #3
big d's red67
I have the bezel out of the truck, I need to get the non tach lens out so I can change it for one with the tach lens. I should have been more clear sorry.
Old 09-10-2012, 11:58 AM   #4
Coley
Coley's Avatar
Smile Re: Instrument bezel lens removal
Lay the dash system face down on a towel or a soft surface with the back facing upwards.
Take a 1/4" socket driver (or equivalent) and undo all the small outer screws holding the (silver-ish) back metal plate on. I think there is something like 8 of them and these screws are found on the outer perimeter edge of the plate...screwed into the plastic bezel.
Remove the main back (silver-ish) plate with all the inner guages 'stuck' (ie: mounted) to it.
then carefully remove the black main inner plate. This will expose the existing lens that you have nested inside the plastic bezel.
Carefully remove it and install your news lens (clean it very well....both sides first!!).
Reverse the procedure above and re-install in your dash.
Good Luck
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-10-2012, 01:32 PM   #5
big d's red67
Good Luck
Coley
Thanks I'll give that a try.
Old 09-11-2012, 04:22 AM   #6
big d's red67
Coley, thanks for the info worked perfectly. Thats why I love this site.
