Old 09-10-2012, 01:22 PM   #1
george ac
Exclamation Can only blame myself
Hello guys here's my dilemma. I Replaced cam shaft sensor, auto zone guy said that should clear the check engine light.Truck was running now its not,I cheked voltage going to new cps and got 12 volts it wont start or attempt to start I didn't move distributor I only removed rotor and cranked engine with coil wire removed(so no to start) until reluctor opening lined up with cps for removal could that mess up timing? since no success I also tried putting the old cps back in and nothing.Last but not least its my work truck so I feel like super Idiot! If someone can help me out Please and thanks!
george ac is offline   Reply With Quote
Old 09-10-2012, 02:33 PM   #2
LEEVON
Moderator
LEEVON's Avatar
Re: Can only blame myself
Welcome to the forum. Sorry I can't really help with that but I know you will get somebody chime in soon. If I still lived in Pines I'd stop in and say hi! We lived on NW 15th Court just a block off Douglas and Taft.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-11-2012, 07:20 AM   #3
BigBlocksRule
Check the plug on the back of your dizzy. When I replaced mine recently, I managed to bend a pin when I plugged it back in. It ran, but not very well. Are you getting spark at all?
BigBlocksRule is offline   Reply With Quote
Old 09-12-2012, 02:29 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I was gonna to check all the plugs on the back of the distributor and make sure there all making connections and none of the pins got bent. Without actually pulling the distributor your timing still should be right!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 09-12-2012, 05:11 PM   #5
george ac
Thanks so much gentlemen,fought with this thing for hours I checked the pins behind dizzy they were fine.I was getting a steady spark at coil but a weak spark at plugs, replaced coil (out of frustration) same result put the old one back in.A friend had come over to help me out I suggested moving dizzy a little either way he said it wouldn't make a difference there is no adjustment that's what the crank shaft sensor is for, not to bore you guys he notice something odd about the C shaped dizzy hold down piece (wrong one for vehicle) turned dizzy and bingo! Motor was swaped by a clown about ten months ago who never responded to the first warranty situation I'm sure you guys are familiar with these rip off artists (they're all over).Again I want to thank you all! And should you ever need help in the a/c or major appliance field don't hesitate to contact me! God bless, George
Old 09-12-2012, 05:17 PM   #6
george ac
Hey Leevon solved the problem if you seen the post.I'm on 86 ave. off of Johnson st. It' a small world.If there's anything I can do for you around here give me a hollar! George
