Old 09-10-2012, 05:29 PM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Gremlin...May be easy for some...
The truck ran fine in the driveway on a new 3-week old build until yesterday.
Started with a "breath" on the key.
This morning, there was =no spark at the plugs. Turned over, and over and over. Plenty of gas in the carb. Not even a "pop"! With the key on, there's constant voltage at the HEI plug.
And there's power at all spots I checked from the fuse box out to the HEI. I didn't measure the voltage.
Yesterday, I had a horn problem....And, with the help of Forum Members, fixed that...It was a problem at the horn ring.
I re-pulled the wheel and checked all the stuff I did yesterday, looking for any possible connection to this problem.
Main question(s), aside from looking for a couple of , "Hey, Magwa, check this....", is if there's power at the distributor plug, and no spark at the plugs,
could it be anything else but the distributor?
Earlier shot:
If no, what if I pull the top part (coil, I guess) and replace that? Does that make any sense. Is there a reason it would fail from perfect to no-go overnight?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 09-10-2012, 05:50 PM   #2
cleszkie
cleszkie's Avatar
Re: Gremlin...May be easy for some...
Pull a spark plug, connect the plug wire to it and touch the plug electrode to a grounded surface while a friend cranks the engine or you crank it with a remore starter switch. If you see a spark, your distributor is likely not the problem unless it rotated and lost the initial timing adjustment. If you don't see a spark, chances are your ignition module has died and needs to be replaced. Make sure you are running a full 12 volts to the HEI. if you are splicing into the original resistor wire that was used to power the points dizzy, you will be getting less than 12 volts and this can cause module failure. Good luck.
cleszkie is offline   Reply With Quote
Old 09-10-2012, 06:04 PM   #3
truckster
truckster's Avatar
X2 on the module. If there's no spark and you have 12v at the distributor, that's likely the cause.
truckster is offline   Reply With Quote
Old 09-10-2012, 06:11 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
X3 on module...this is a reminder for me to buy an extra and keep it in the glovebox...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-10-2012, 07:01 PM   #5
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
If you have the coil off check for resistance with a multimeter between the positive and negative wires. If there is resistance, you're good. If there is none or infinite, you need a new one.
I've fried two in the last two months, but both were running failures.
The tach also won't read while cranking if the coil's bad.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-10-2012, 07:13 PM   #6
magwakeenercew2jh
Okay. The grandkid gets off the High School bus at 3:30. So, even though the headers make it a PIA to get a plug out (I was going to see if just the the wire with a nice sized bolt making contact
inside the boot shorted against the head, but cleszkie convinced me that the plug had to come out to get a *real* spark-or.... no spark). So, I did.
Set it up, went to the bus and picked him up. Explained the procedure and that he needed to shut down IMMEDIATELY when I raised 4 fngers over the hood. And that hbe was NOT to use the
accelerator during this test. Got a pair of needle nose pliers. Grabbed the plug boot. Put the electrode up against the head. Yelled "Okay, Will!"
F%$#ing thing fired off on seven...like RIGHT NOW. I pulled back. Touched my test rig to the inner fender and my wrist...at the same time. Will was watching for the fingers.
But he saw me go down and made an executive decision to come off of the key....
Never was there a happier fat man laying on the gravel just being wrong. I guess since I had been chasing electrical gremlins in the cab, and the fact that I WAS getting gas to the
carb made this dumb old wrench forget the symptoms of a big, nasty river of flooding.
Thanks, guys for the help.
I'm still going to check to make sure I have a full 12V + at the HEI.
And, I'm going to get an extra module for the glove box.
All's well that ends well.
And, when I was done, I checked at the front door. The UPS Man brought me my M & H Under Dash Wiring Harness....Yay!!!!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 09-10-2012, 07:25 PM   #7
ERASER5
ERASER5's Avatar
Glad you didn't get hurt. I must admit, you made me smile.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-10-2012, 08:12 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
x2
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-10-2012, 09:07 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
That spark usually wont hurt you.You'll hurt yourself getting away from it though.
Glad you could get up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-11-2012, 01:35 PM   #10
Lemield
Lemield's Avatar
Ok....I want to know how you got a hold of a picture of me and my brother????
My co-worker and I have been using those guy's picture for some time now...I actually had the guy on the right as my picture in our company namefinder (until my boss told me to stop messing around and act like a professional)
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-11-2012, 04:21 PM   #11
truckster
truckster's Avatar
HEI definitely lets you know when you've gotten too close!
Old 09-11-2012, 10:53 PM   #12
Boog
laying low
Boog's Avatar
OMG. Magwa. That is funny shtuff right there. It reminds me of the story of the guy who bought the taser and tried it out on himself. How bad can a little 9 volt battery be, right? So funny!
Not to laugh at your pain but to visualize this happening. Thank you. I've been bit more than a few times by HEI over the years too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
