Old 09-10-2012, 05:48 PM   #1
Atommik
Atommik's Avatar
How low will it go??
I'm just finishing up mocking up the front sheet metal on my 51, on an s10 frame. How much will the front end go down when I install the motor and trans (327/ TH350). One inch? Two inches? Just wondering so I can start to figure out if I will want to lower the suspension at all.
Atommik is offline   Reply With Quote
Old 09-10-2012, 06:29 PM   #2
fat56
fat56's Avatar
Re: How low will it go??
It all depends on the spring rate or even how old the springs are. Mine is not a s10 but it dropped about a inch - 1 1/5 inch.
Blake. Sydney Aus
56 Chev 3100
build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363
LOW n LOUD
fat56 is offline   Reply With Quote
Old 09-10-2012, 08:52 PM   #3
Rude Dude
Rude Dude's Avatar
My suggestion would be to build it first then if you have to go lower S-10 dropped spindles and lowered springs are readly available and not ex-spensive. If you want to raise it larger stock springs from lets say from an F-Body car will fit.
Rude Dude is offline   Reply With Quote
