Old 09-10-2012, 06:49 PM   #1
ecgate
ecgate's Avatar
Using Stock Upper and Lower A Arms With Air Bags
Can I use my stock upper and lower a arms with a air bag setup or do I need to purchase some after market tubular arms.
ecgate is offline   Reply With Quote
Old 09-10-2012, 09:20 PM   #2
canadian trucker
A day should have 30 hours.
Re: Using Stock Upper and Lower A Arms With Air Bags
No you can use your oem parts.
You will need a bottom cup and upper plate though.
Check out ride tech or Porterbuilt
http://www.porterbuiltfabrication.co...-1963-1987-365
canadian trucker is offline   Reply With Quote
Old 09-10-2012, 09:28 PM   #3
ecgate
ecgate's Avatar
Do you know anything about shimming the upper arm? I guess what im asking is should I expect to use more or less shims?
Old 09-10-2012, 10:39 PM   #4
Pro Performance
Pro Performance's Avatar
It might be a few more if anything, but I could be wrong. You do however, want to figure out where your ride height will be, and align the truck at that height. This will give you the best wear on the tire at the height that sees the most drive time.
Pro Performance is offline   Reply With Quote
Old 09-11-2012, 12:46 AM   #5
Mikec10
Mikec10's Avatar
Possibly a little off topic but are the upper front shock relocaters necessary? If so where can i buy them separately?
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 09-11-2012, 06:08 AM   #6
kev2809
low n' slo
kev2809's Avatar
cpp sells shock extenders, to use your original shocks.
but depending on how low you go, there are shocks off of a 50's model chrysler car if i remember right..that bolt right in and are shorter than stocks. thats what i have in my suburban
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
