Old 09-10-2012, 09:52 PM   #1
Snowbound
Snowbound's Avatar
Did You Go All The Way?
So I'm laying under my truck with a grinder and wire wheel, removing undercoating and dirt from my frame. Arms are burning, crap dropping in my face....I'm thinking it would just be easier to pull the cab and sandblast the frame.
Front clip is off for the engine swap, pulled the box to make the frame detailing and exhaust job easier. All that's left is the cab. Few wires, E-brake, brake lines, steering column and 4 cab mounts......off she comes.
Pull the front suspension - dozen or so bolts.....Rear end and trailing arms/springs, 4 more bolts....
Bare frame ready for the blaster.
Holy snow ball Batman! Started as an engine/trans and disc brake swap.
Does this happen to you guys? Have you ever gone all the way? I'm rounding 2nd base and headed for 3rd.........
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 09-10-2012, 10:01 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Did You Go All The Way?
sorry to say but if its one of your first..most of us have dreams of grandeur.until we are so into a project its really hard to know where to start frist...almost to the point it never gets done.
I have learner to segmint my proect with realistic goals.
maybe start with the farme but ONLY work on it from the back of the cab to the rear...Or ONLY work on the bed...Or ONLY one door at a time until its DONE.
any project can become overwelming in the BIG picture.
focus on the smaller picture..
Good luck............
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 09-10-2012, 10:08 PM   #3
66clow
66clow's Avatar
I know what you mean, I've been there. I have a 64 el camino that I was repairing a dent on the top of the fender. There was a softball size dent on the top and pretty deep. The po made it easy for himself and just laid down an inch of bondo that started cracking. The only was to really access it was to pull the fender off. I had to go in and repair it correctly. Unfortunately I ended up pulling the hood off, hlamps, grille, and pulled the left fender off as well because they screwed that side up also. All that to repair a small dent that took about 10 minutes to easily knock out once everything was out of the way. I'm exhausted thinking about it now. Gotta go all the way sometime!
66clow is offline   Reply With Quote
Old 09-10-2012, 10:11 PM   #4
66clow
66clow's Avatar
Nice truck btw! Gotta get me some WW.
Old 09-10-2012, 10:53 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
My last two builds were like that. I didn’t take apart every single nut and bolt, but one thing led to another until almost everything was disassembled.
On the 46 sedan I started out wanting to steam clean the engine compartment and swap in a small block Chevy. It made it this far apart before going back together:
The truck was rebuilt in stages, but when it came time for the first paint job it got taken apart this far to gain access to everything that needed to be painted:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 09-10-2012, 10:58 PM   #6
198plus
198plus's Avatar
All the way......It's a sickness
198plus is offline   Reply With Quote
Old 09-10-2012, 11:21 PM   #7
Narxoleptic Customs
It's tough... The simple c-notch has become hangers, rear axle, 2-link, bags, and a tranny...
Narxoleptic Customs is offline   Reply With Quote
Old 09-10-2012, 11:25 PM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
This is my problem, and has been since I got bit by the 'bug' since I was a child.
"There has got to be a way to make this thing cleaner ... Lets take it apart !!"
I have tons of projects waiting there turn.
Just plan for it, and if you know you can do it ...then go for it.
Otherwise, consider it a 'mock-up' ... get your swap/brakes going...then someday rip it apart.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-10-2012, 11:41 PM   #9
RockTonka
RockTonka's Avatar
Tough call..."it will never be easier than now" can bite ya in the ass.
We have projects going on for years now because we have taken that route (for all the right reasons) and also a couple that we are working through in stages so we can continue to enjoy them while we are working on them...I think I like it better this way.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 09-11-2012, 12:57 AM   #10
LT1 Burb
LT1 Burb's Avatar
Powder coating is the way to go, I didn't have to wire wheel anything.
LT1 Burb is offline   Reply With Quote
Old 09-11-2012, 01:42 AM   #11
Snowbound
Snowbound's Avatar
My biggest issue is lack of space.
Not sure where I would put the cab if I pull it. Up hill driveway with a gravel pad at the side. Can't wheel the cherry picker out there.
I guess the small space keeps these projects withing my abilities!
Old 09-11-2012, 02:42 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mine started as a "Clean up to drive and maybe a rattle can paint job to get one color" to "full drivetrain swap, new interior, new stereo, new wheels, new paint, new brakes" and I'm still waiting on the bed part of the project along with other stuff. I'm 3 years into a 3month project.
I was lucky in a since that although the P.o mostly screwed up my truck, he did 2 things right. He did a body off to clean and paint the frame and put the 72 front and rear ends under it. So pulling the cab back off didn't need to happen for me.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-11-2012, 04:50 AM   #13
pdxhall
pdxhall's Avatar
I went in to mine with the purpose of a total tear down and rebuild, but as others have said, it is important to have a plan before you start and try to keep to it. Being able to see progress on one part gives you incentive to finish so you can start the next phase. I too had limited space so I started in sections. The front suspension first. Tear down, cleanup, paint, and rebuild the front suspension. Then the rear suspension. With both ends done, the cab came off next and the remainder of the frame was completed. Now it's rust repair on the cab so the bottom of the cab can be cleaned up and set back on the frame....and on and on it goes.
pdxhall is offline   Reply With Quote
Old 09-11-2012, 12:56 PM   #14
61K10
61K10's Avatar
the rewards at the end justifies all the hard work. time is one of the biggest problems as is funds. many years ago i took 4 layers of paint off a Nomad with paint remover. took forever.(had the car for 24 yrs) I have the time now being retired, but only so much funds per month being on a fixed income. posting some pics of some stuff to see the results of some projects. just keep it fun----first is my new project 61k10 the rest is kinda before and after. saws were like the before bike------hope i am not boring anybody with this post.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-11-2012, 01:04 PM   #15
61K10
61K10's Avatar
forgot my new project------and the saws are 1st one with the long bar is a 1964 Mccullach red one is a 1957 Homelite and the other yellow on is a 1958 Mac. would like to display these in back of the truck someday. thanks for putting with me----
1961 chevy K10
Old 09-11-2012, 01:10 PM   #16
hopped up
hopped up's Avatar
Nice yz!! 85? I have an 85 too!
hopped up is offline   Reply With Quote
Old 09-11-2012, 01:23 PM   #17
61K10
61K10's Avatar
yes a 85 125. did an 82 also and a 85 TT600.
1961 chevy K10
Old 09-11-2012, 01:24 PM   #18
Rich 5150 69
Rich 5150 69's Avatar
This time around will be do all the changes while driving it, rear is just about done, front will be next, aguire evrything thing I`ll need in the soft ware that I`ll need..then blow apart for paint. Try to minimise the down time. Last one I did took four years down, originally started as engine transplant, yes they snowball in a hurry.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
