Old 09-11-2012, 11:01 AM   #1
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Hood springs
My old srpings where a bit weak , thus I bought a new set from one of the after market places I forget where. LOL these are worse than my old ones. SO the question is what OEM spring will swap in place and where can I get it??
GMR-PERFORMANCE is offline   Reply With Quote
Old 09-11-2012, 11:18 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Hood springs
LMC Truck should have decent springs and if you don't like them they will take them back. OEM is probably not out there. I would call and talk to a tech and tell him of your current problem with aftermarket springs and see what he says about his stuff or just keep your weak springs. I think I got mine at chevyduty at the time whcih is now classic truck parts. http://www.classicparts.com/1960-66-...ctinfo/38-413/ I think I got mine here. It was like 12 years ago. I didn't paint them I just ran them through the poisher and they never rusted.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-11-2012, 11:24 AM   #3
GMR-PERFORMANCE
Re: Hood springs
I bought these from classic parts,,,When you put the hood up it will drop down a few inches. I can tell you that they where easy to install.. I took a large rubber coated hook for hanging a bike in your garage and screwed it into a 2 inch that wood dowel. and it was super easy to install I can tell you that the old ones are stiffer.. But those still drop just a bit, thus I bought new ones thinking that would be the fix.
Just wondering if this is only an issue on my end ,..that is not wide spread.
Was hoping that maybe a newer spring off something would swap directly over.
Well I called them and they told me that my hinges are to be extremely stiff and that is what helps with holding the hood up..
BTW all factory parts from hinges to sheet metal.. The hinges do move smoothly and do not have a bunch of resistance.. but they are not sloppy..
They are sending anthoer set for free to try.. it may just be that my hinges are wron and that is the issue. I may take them off and use an air hammer or my press to try and tighten that rivit up some.
Old 09-11-2012, 05:57 PM   #4
62 Longbed
62 Longbed's Avatar
Re: Hood springs
If those don't work ... I believe I still have some good O.E. ones lying in the garage ... There yours for the cost of shipping if interested ...
62 Longbed is offline   Reply With Quote
Old 09-11-2012, 05:59 PM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Hood springs
Would new springs help bring the rear of the hood down? Mine stays up fine with no drop, but the rear is jacked up a little.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-11-2012, 07:19 PM   #6
Chevy Fleetside
Re: Hood springs
I would take that deal.
Old 09-11-2012, 08:41 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Hood springs
New springs won’t help. Your hinges are out of adjustment and will need correction, shimming, or replacement depending on what’s wrong. Here are the factory instructions on how to align the hood. Paragraph 4b, 4c & 4d on the third page address the rear height of the hood::
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
