Old 09-11-2012, 02:51 PM   #1
chvyboy
chvyboy's Avatar
Exclamation Rear sway bar
New to sway bars and since I have the bed off why not install one, so my question is, what is the best bang for your buck? Does anyone have any good photo of an installed rear sway bar?
My project: Spare change
http://67-72chevytrucks.com/vboard/s...=1#post5031992
chvyboy is offline   Reply With Quote
Old 09-11-2012, 06:10 PM   #2
Xeen
Xeen's Avatar
Re: Rear sway bar
Classic Performance Products makes a 1-1/8" OD high performance rear sway bar for Coil spring for $139.00 and a 7/8" OD high performance rear sway bar for Leaf spring for $149.00, thats good bang for your buck.
Heres a Link.
http://www.classicperform.com/6092chevtrk.htm#36
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-11-2012, 10:45 PM   #3
Tinkermc
Re: Rear sway bar
Front and rear bars make a hugh difference in Handling
Tinkermc is offline   Reply With Quote
Old 09-11-2012, 11:39 PM   #4
davepl
davepl's Avatar
Re: Rear sway bar
I just installed the rear one available from LMC, and I don't think its really intended for our trucks. The end links are nowhere near long enough to reach up to the frame on a leaf spring truck unless you rotate the whole thing so that the mounts are pretty much on TOP of the axle.
The picture at classicperform.com looks like the same unit I got from LMC, so just a heads up.
I'm not saying they -won't- work, just surprised at the way it fit.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-11-2012, 11:44 PM   #5
GuyO
GuyO's Avatar
Re: Rear sway bar
Don't have pictures, but I put Hellwig 1 1/8" front and rear anti-sways in SWB. HUGE difference on old springs. I bought new and had them installed, but wrecking yard C30 sways or off of a Custom Campers would be much less expensive if you can find them. I also did a "performance" alignment. Very happy with handling.
GuyO is offline   Reply With Quote
