Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 09-11-2012, 04:51 PM   #1
Walleye
Walleye's Avatar
WTB - pulley set for '72 Blazer
I am swapping out the newer model 350 SB back to an original style 350 SB in my "72 Blazer. I am need of
- 3 groove "flush mount" crank pulley for the original motor (with A/C)
- 1 groove alternator pulley
- 1 groove short water pump pulley
- 1 groove power steering pulley
I would like to purchase complete set from 1 seller if possible.
Walleye is offline   Reply With Quote
Old 09-11-2012, 04:54 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: WTB - pulley set for '72 Blazer
Wouldn't you need two groove for the water? And single for ps? Do you need the brackets also? I have one complete extra set. (Corrected with the info from wes)
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-11-2012, 04:56 PM   #3
Walleye
Walleye's Avatar
You are correct. Pulleys and brackets would be great...Thanks.
I also need exhaust manifolds if you have a set.
Please PM the price.
Old 09-11-2012, 06:33 PM   #4
Classic Bowties
Always on the hunt...
Originally Posted by Walleye View Post
I am need of
Originally Posted by VA72C10 View Post
Wouldn't you need three groove for the water also? And two for ps?
To be OE on a 72 blazer with a 350, ps & factory ac (not dealer type) he would need: 2 groove wp pulley #646, 2 groove inner crank pulley #043, 1 groove outer crank ps add on pulley #232 and a 1 groove ps pump pulley #325. Mel
Classic Bowties is offline   Reply With Quote
Old 09-11-2012, 06:45 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
Thanks mel for the part #'s and correct info I just knew it wasn't single groove w/p. I think I have all of these and will post pictures tonight.
Old 09-11-2012, 06:46 PM   #6
Walleye
Walleye's Avatar
I appreciate the help/education on these parts!
Old 09-11-2012, 08:46 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Okay, what I have is a complete setup but not the same....I think the extra pulley might be for an air pump? (4 for the crank)
Ps pulley 3925537 (maybe difference is press on vs bolt on?)
Wp pulley 3995646
Inner crank 3744043
Outer crank (cast iron two groove) 3923898
Brackets are a mix of cast and steel also...
Any confirmation on these wes? I believe them to be correct with a/c and swp (they were sold to me as)
Old 09-19-2012, 09:30 PM   #8
Thelast 72k5
If those dont work out for you i think i still have everything "pulleys and brackets" that came off my 72. It was and original air truck.
Thelast 72k5 is offline   Reply With Quote
Old 09-19-2012, 09:48 PM   #9
Walleye
Walleye's Avatar
Sounds good...I will let you know the results soon. Thanks
