Need Help!!!
DM guys, My frame Will not set level when aired out. Nate said something must be binding. Have any of yall ran into this problem?
Eric K |
Re: Need Help!!!
Did you notice if the frame was straight before the installation? Have you had a chance to take some measurements to find out exactly where it starts to twist? In front of the notch? Behind the notch? etc.
Start there, and let us know what you find. If it's behind the notch, it might be as easy as loosening some bolts and tweaking the rear rails a little.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Re: Need Help!!!
Haven't had to time to measure anything. Looks like the frame lays good before the notch. Should I take the back half off and reinstall or just start loosening everything up?
Eric K |
#4 | |
Re: Need Help!!!
Let us know what you find and if you need to call for any help don't hesitate to do so. Nate
Re: Need Help!!!
This might be a stupid question. Is it possible that tha air bags are different? It looks like one of the bags collapses down more than the other.
Eric K |
#6 | |
Re: Need Help!!!
![]() The sleeved bags need some air pressure in them when you deflate so they can roll over themselves. Otherwise they can bunch up. Maybe that's what happened???? Nate
Re: Need Help!!!
That's my next step. Maybe this weekend. Thanks again Nate!!
Eric K |
