Old 09-12-2012, 05:47 PM   #1
kiles_2001
Question rear end question
Hello everyone... I have a dilemma and need help, I have a 1969 c10 with a six lug leaf spring rear end, my rear end housing is pretty rusted and pitted... I wanted to convert the rear end over to five lugs because it is a posi rear end with 3.73 gears which is exactly what I wanted to run, my question is... can I pull out the posi unit and gears and get a newer rear end and install it into that rear end and into my truck? can anyone give me some insight on the matter and point me in the right direction please???
kiles_2001 is offline   Reply With Quote
Old 09-12-2012, 08:07 PM   #2
HotRod C/10
HotRod C/10's Avatar
Re: rear end question
would have to be the early rearend unfortunately....71-71 was 1.5" longer.....
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 09-13-2012, 08:42 PM   #3
Daves70
Daves70's Avatar
Like Hotrod C/10 said. 1.5 inches wider. Depending on your rim choice it will work. A 70-82 12 bolt of the same series should accept your gears and posi.I did it the other way, I put newer gears and carrier in my 70 housing and it worked. All this is provided you have a 12 bolt and not a dana.
Daves70 is offline   Reply With Quote
Old 09-14-2012, 01:39 AM   #4
kiles_2001
yes it is a regular 12 bolt just a leaf spring rear end, so I can get a newer 72-85? the 1.5 extra is ok, I am going to run 295/50/15 on 8'' rims, I should be ok....
Old 09-14-2012, 03:25 AM   #5
luvbowties
luvbowties's Avatar
That 1.5" may give problems w/8" wheels should you have a lowered stepside--fleetside is more forgiving & more clearance.
sam
luvbowties is offline   Reply With Quote
Old 10-07-2012, 10:40 PM   #6
kiles_2001
I think you are right, luckily I checked my rear end and the pitting seems to be surface rust... now I just have to figure out what axles to order, how can I identify which ones I need to order???
