Old 05-26-2003, 10:45 PM   #1
71Custom10
71Custom10's Avatar
Question Problem Installing U-Joints
Everytime I replace u-joints I always have a problem getting 1 out of thr 4 clips in. Three go in with no problem. The 4th cap always sets about 1/16-1/32 to high. No matter what I do it won't go down enough to get the clip in. Anybody else had this problem? What am I doing wrong? Andrew
'67 Chevy Longbed Fleetside - Daily Driver(For Now)
'72 Cheyene Longbed Fleetside-Daily Driver
Best Towing Service
71Custom10 is offline   Reply With Quote
Old 05-26-2003, 10:49 PM   #2
Class of 69
Class of 69's Avatar
Common problem! I have to beat the joint back into the cap on the opposite side very convincingly to seat it...clip should then go in, if not, repeat beating!! Don't break anything tho!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 05-26-2003, 11:24 PM   #3
jef5150
Inline 69
jef5150's Avatar
try using a socket thats just alittle smaller diameter than the diameter of your yoke opening
jef5150 is offline   Reply With Quote
Old 05-27-2003, 02:15 AM   #4
fine69
fine69's Avatar
Make sure and clean out your grooves. Sometimes i have to sand down the ends of the caps. Wetsanding works well. Get some 600 wet/dry paper. It will work good. Takes a few minutes. But worth the effort. Better than beating the crap out of the ujoint.
fine69 is offline   Reply With Quote
Old 05-27-2003, 03:21 AM   #5
jimfulco
Make sure one of the little needle bearings didn't fall out of place & get in the way. They are about 1/32" to 1/16" thick. (Do this before bashing, etc.)
jimfulco is offline   Reply With Quote
