Old 09-13-2012, 10:25 AM   #1
slugish
Slugish
Fire in the carb
Have got my engine cranked a few times since heads & cam change.
Most of the time i have to spray starter fluid in holley double pumper to get it to fire .
Recently the carb catches on fire when attempting to crank > should i not use starter fluid ?
Also the front 2 primaries are not squirting gas > only the back secondaries squirt when throttle opens up past half way .
Have moved dist . Every way possible .
What can i do ?
slugish is offline   Reply With Quote
Old 09-13-2012, 10:34 AM   #2
geunther
geunther's Avatar
Re: Fire in the carb
Distributors have a tendency to get turned 180 degrees. This can cause the symptoms you are seeing. Except for the primary accelerator pump not squirting. It becomes a chore so you can either just try to set it 180 from where it is now, or the better way, but requires more work is to:
Ensure #1 is at TDC with both valves closed and then making sure the pickup in distributor is pointing the the #1 spark plug wire.
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
Old 09-13-2012, 11:35 AM   #3
mopar346
We have been through the set up a number of times, it's still the same info from your last few threads. I think it is time to get someone else to look at it cause you are overlooking something.
Carb has a problem unrelated to your timing and adjustments.
Starting fluid is not good on an engine cause it is very dry and has no lubricating properties.
By the way, when one backfires and flames up, keep spinning it, it sucks the flame down into the engine and causes it to go out plus it protects everything else from fire.
Again, I think it is time to get an extra set of eyes.
mopar346 is offline   Reply With Quote
Old 09-13-2012, 01:00 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
How old is your Holley. If you backfired you may need to replace your power valve if your carb is not equipped for power valve blowout protection. If your bowl screws are flathead then it's one of these that needs an update
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-13-2012, 03:46 PM   #5
mrhino
better get it looked at. You dont wont to end up like this guy!
mrhino is offline   Reply With Quote
Old 09-13-2012, 07:01 PM   #6
slugish
Slugish
Originally Posted by mopar346 View Post
we have been through the set up a number of times, it's still the same info from your last few threads. I think it is time to get someone else to look at it cause you are overlooking something.
Again, i think it is time to get an extra set of eyes.
yea me too > appreciate your help
Old 09-13-2012, 07:06 PM   #7
slugish
Slugish
Originally Posted by insidious '86 View Post
how old is your holley. If you backfired you may need to replace your power valve if your carb is not equipped for power valve blowout protection. If your bowl screws are flathead then it's one of these that needs an update
posted via mobile device
yea carb has backfired 3-4 times due to dumb me crossing 2 of the plug wires. Would the power valve being blown out have anything to do with primaries not squirting .
Yea bowl screws are flathead , but carb is one from aed ( very good carb techs ) take old hollleys & redo them . Good reputation !not that old .
Old 09-13-2012, 10:50 PM   #8
bigwheel15
bigwheel15's Avatar
Windsor truck fire - YouTube
Ford or not, that video hurt to watch.
bigwheel15 is offline   Reply With Quote
Old 09-13-2012, 11:56 PM   #9
Projectbadass
I'd cry if that happened to me
Projectbadass is offline   Reply With Quote
Old 09-14-2012, 02:11 AM   #10
INSIDIOUS '86
Well then it may already have it.
Old 09-14-2012, 05:52 AM   #11
mopar346
Fuel squirt when you stroke the throttle is controlled by the accelerator pump not the power valve. I have never known a backfire to damage an accelerator pump.
Old 09-14-2012, 10:09 AM   #12
geezer#99
geezer#99's Avatar
I didn't cry when my truck burned to the ground. I just swore a lot more than he did. Mine was more spectacular. At midnight! Towering inferno! 74 chevy swb ss too.
At least I still had a tailgate left over.
Lesson learned!
DON"T USE RUBBER FUEL LINES!!!!
