09-13-2012, 11:33 AM | #1 |
Need some advice with my 67'!
Alright so this summer me and my dad swapped in a 350, and kept the old 3 speed trans. I have no clue what my rear end ratio is but my best guess is 3:73. The rear end is not original to the truck, back in the 90s my dad had this one swapped in when his old one crapped out on him. At 60 MPH im turning about 2800-2900 RPMs. This seems pretty high to me, i need some advice on which direction to go.. A new trans or swap rear end gears. I do travel lots of interstate miles because i have to drive about 220 miles to college every now and then, and thats not too fun at 55 MPH.
09-13-2012, 11:38 AM | #2 |
Re: Need some advice with my 67'!
Check out this thread, lots of good info in there.
http://67-72chevytrucks.com/vboard/s...d.php?t=542702 |
09-13-2012, 11:48 AM | #3 |
A good 700R4 with 1:1 lockup and more of a cruise gear would help a bunch IMO.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
09-13-2012, 12:14 PM | #4 |
If you've got the money and the inclination to do some work, a 700R4 is a good candidate. You really need to figure out what your rear end ratio is. It's not hard:
Put the trans in neutral. Jack up one of the rear tires. Make a mark on the tire and and on the driveshaft. Turn the wheel until the driveshaft makes one complete rotation Count the rotations of the wheel. If the wheel makes 3 3/4 rotations, you have a 3.73. If it's slightly more than three, it's likely a 3.07. If it goes a little more than 4, it's a 4.11, and if it goes about 4 1/2, it's a 4.56. Those seem to be the most common ratios. |
09-13-2012, 12:22 PM | #5 | |
09-13-2012, 12:30 PM | #6 | ||
"I ain't nobody, dork."
The T5 out of an S10 or a Camaro are weak transmissions for a heavy old truck if you ask me. There are better 5 and 6 speed transmissions out there.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
09-13-2012, 12:32 PM | #7 |
Okay, well im really wanting to stick to something manual so hopefully i can come up with something thats not too weak for my truck, and can get my down the interstate better. Thanks for the help
09-13-2012, 01:12 PM | #8 | ||
There are cats that do use the T5's in these trucks... there is even a "how to" Camaro T5 install on here somewhere.
But me personally... with the way I drive... I would want something way stouter. Especially if the truck is used for any kind of towing or hauling. Gary
09-13-2012, 01:31 PM | #9 | |
09-13-2012, 02:01 PM | #10 |
No, if you're concerned primarily with highway driving, the final gear ratio is what matters. There are some later-model 5-speeds with overdrive that can be swapped in, but I believe you have to fabricate a mount for the hydraulic clutch.
As I've gotten older (I hate to admit that) I've come to appreciate the automatic more. Only one of my six vehicles has a manual, and that's a little Geo Tracker. But I understand your wanting to mix it yourself. There are some good older threads on the forum. I'd do a search for manual trans swap and see what you come up with. |
09-13-2012, 02:42 PM | #11 |
Grandpa in the rustmobile...
Run it like it is! lol
t-5 200r4 700r4 nv3500 nv3500 all GM OD trans auto and manuals
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-14-2012, 08:03 AM | #12 |
Thanks! well for now i think im just going to take your advice and run her like she is and just take my time cruisin on the interstate!
1967 c10 swb 4th generation in my family http://67-72chevytrucks.com/vboard/s...d.php?t=516458 |
