09-13-2012, 04:10 PM | #1 |
1964 K10 Lift Help...
Has anyone lifted their FWD Chevy from this time period? Having trouble finding any information on it.
Thanks Eddie |
09-13-2012, 05:18 PM | #2 |
Re: 1964 K10 Lift Help...
They already have a lift from factory maybe you could do a body lift. Do not know of any thing available for these trucks
09-13-2012, 09:35 PM | #3 |
1966 Chevy/GMC Mongrel K10
Depends on how high you want to go. Late 70's to 80"s CJ7 add a leafs(if they're still around) can give you an inch or two. Higher than that and you'll probably have to go to a $pring $hop and have them made. I've never seen a production lift kit for GM trucks any earlier than 67.
09-14-2012, 12:07 AM | #4 |
60-66 Nut
Lift kits for the '68 and earlier K series trucks basically do not exist other than being custom made. If you need more lift that what was stock, I would suggest changing your spring mounts to accept the '73-'87 style springs. You can then either use an off the shelf lift for the '73-'87 or use the 56" springs with a shackle flip in the rear and the 52" springs up front with the parts from diy4x.com.
09-14-2012, 04:59 AM | #5 |
Thanks Guys
